Casting # Size on 61 Corvette Engine
I have to look at a 61 later today and I can't remember, which casting # size is correct, the large font 539 or small font 539? I think small font is original for a corvette, but I am not positive. Thanks!
The original casting # for 61 is #3756519 or if very late #3789935. The Saginaw casting, correct for Corvette on the casting date the year is a single digit. Not sure of the font size of the casting # for 283s but for 327s the font is larger on Saginaw castings.
My memory is really foggy, got the casting # wrong. In any case, they had two different fonts for the #, I believe one was used in non corvette applications and the other was used in Corvettes.
Regards
Casting numbers are 5/8" high for the correct Flint blocks, correct for the corvette as opposed to the Tonawanda blocks that had the 9/16" high numbers. The other way to determine the Flint blocks from the Tonawanda blocks is the Flint blocks had the one digit year designation as opposed to the Tonawanda blocks that had the two digit year designation. The 519 Flint block is correct as well as the 935 block from approx serial # 9,500 to the model end June-July. The Tonawanda 519 blocks are not a correct corvette application
My original '61 is VERY late - like 100 cars from the end of production and has the 519 block...
Received 1,858 Likes
Nope. Neither the Saginaw Foundry nor the Machining Department at Flint V-8 had the slightest clue what the final application was for any block; they were all the same until they went down the engine assembly line and got internals and externals.
