Barn Find Value
Old Dec 6, 2012 | 05:02 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Default Barn Find Value
I have recently taken possession of a rare barn find and I need a value. I have the original axe that George Washington used to chop down the family cherry tree! It is in very good origonal condition. The handle has been replaced three times and the head was replaced only twice but all parts were OEM!!!! This is the original axe!!!!! How much do you think it is worth?
Tom
Old Dec 6, 2012 | 05:11 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Is the replacement handle made out of cherry wood from the tree he cut down? If you can verify that it will be worth more. Does the ax still have the build sheet on it?
Old Dec 6, 2012 | 05:20 PM
6D2148's Avatar
6D2148
stuff does get thick, doesn't it?????????????????????????
Old Dec 6, 2012 | 05:21 PM
Sky65's Avatar
Sky65
The handle is oak but the numbers appear to match the head. I guess that means a re-stamp? Previous owner claims to have documentation of the OEM replacement parts but I haven't seen it yet. Don't know about the build sheet. I'm not sure if early production axes had build sheets?
Tom
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
It's like honey on a cold day
Old Dec 6, 2012 | 05:31 PM
Bowtyeguy's Avatar
Bowtyeguy
AXE on the Cherrytree Forum
Old Dec 6, 2012 | 05:32 PM
426 Hemi's Avatar
426 Hemi
The value goes up proportional to the amount of rust, bird poop and cat tracks on it.
Old Dec 6, 2012 | 05:33 PM
66jack's Avatar
66jack
Thats the 'cherry' PITS
Old Dec 6, 2012 | 06:13 PM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
You might try the Axe Forum to see if you can locate any documentation and paperwork on this unit. Would add greatly to the value.
Old Dec 6, 2012 | 06:16 PM
StingU2's Avatar
StingU2
Tom
Tom... is it #1, #2, #3, or #4? Good ole' George had more than one axe...
Bruce
Old Dec 6, 2012 | 06:17 PM
rene-paul's Avatar
rene-paul
Axe handles are Hickory, you may have a repop.
Brgds,
Rene
Old Dec 6, 2012 | 06:20 PM
Velox's Avatar
Velox
I almost bought an original AXE like yours last year but I was able to run the numbers at Real_Axe_Registry.org and turns out somebody else had a state re-issued AXE license for the one I was going to buy.
Old Dec 6, 2012 | 06:28 PM
woodsdesign's Avatar
woodsdesign
Any documentation?
Old Dec 6, 2012 | 06:31 PM
tgtexas02's Avatar
tgtexas02
Guess you can reluctantly go for a Top Flight instead of Bowtie?
Old Dec 6, 2012 | 06:41 PM
StingU2's Avatar
StingU2
Tom
Tom
If it's the same axe he used to cut down the cherry tree to make his wooden teeth that axe could be worth a boat load of money... Yes, that very same boat he used to cross the Delaware
A little trivia... did you know that everything George ate tasted like cherries
Bruce
Old Dec 6, 2012 | 06:51 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Tom, I'm getting a little concerned about you. What's next, run flats on all four corners? Dennis
Old Dec 6, 2012 | 08:40 PM
GreaseMonkey's Avatar
GreaseMonkey
PA Events Coordinator
Or the NARS....
To Barn Find Value
Old Dec 6, 2012 | 09:16 PM
Sky65's Avatar
Sky65
Hmmmm. Lots of good suggestions here. I never thought about trying the Real_Axe_Registry.org or Cherrytree Forum. And I didn't know GW had more than one. I wonder how many of the others are still around? I thought for sure I had a one of one. Oh well. Don't think I will have it judged. Takes too much effort a I don't want to end up with a garage queen. Maybe I will build a Resto-Axe! You know update it with a Titanium head and a Carbon Fiber handle!
Tom
Old Dec 6, 2012 | 09:17 PM
fishingdan's Avatar
fishingdan
St. Jude Donor '10 thru '24
I don't nose the answer to your question. Axe me another one.
Old Dec 6, 2012 | 09:42 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
OK Tom, time for you to find employment again. Retirement is affecting your thought process. I'll give you five bucks for the axe head on the probable value to the Smithsonian.
