Replating
I think eastwoods sells a kit, but get a lot of extra plates....they go pretty quickly.
if I dont like how they turn out - he has always made them right !!
Most zinc done today is treated with Chromate to make it more durable. There is a clear chromate, which imparts a clear, slightly blue cast to the parts, and this is the bright shiny finish that you see on most nuts and bolts today. Yellow chromate is also used, and it imparts a gold tone with kind of a rainbow effect in places. The same chromate treatments are used with cad finishes as well, but the yellow chromate is the most prevalent finish, because the color gives a good indication of the level of treatment. The darker the finish, the more durable the plating. The chromate combines with the metal zinc or cad, to form a zinc dichromate or cadmium dichromate finish on the surface of the plating. This finish makes the plating way more durable.
If you really want Cad plating done, look at places that rebuild Aircraft propellers. It is one of the few applications, where you are not allowed to substitute zinc for cad. I have my radio cases re-plated with cad, at Jordan Propeller in San Antonio. C1 radio cases have leads soldered to the case, and you can solder easily to cad, but zinc is hard to solder to.
Regards, John McGraw
Even this shiny zinc will dull down over time. If you ask your plater to make the parts slightly less shiny, I am sure that he can accommodate you.
Most shops have a minimum charge that is in the $75 range, so it is to your advantage to take as many parts as possible to maximize the value. You can take them window tracks, hood support and the like, and probably still not exceed the minimum charge. Zinc plating is not the labor intensive process that chrome is, so you can do a lot of stuff for $75. This minimum charge is the main reason that I set up a plating tank 10 years ago, just to do my stuff.
My advice would be to drill out the rivets in the hood hinges and hood support before replating and replace them after you get the parts back. The spring washers under the rivets will usually fail if left on the parts for plating, because of hydrogen embrittlement. The completed plating will look way better as well. Most often, these rivets are getting loose anyway, and the spring washers have lost a lot of their tension.
Now, with all this being said, new reproductions are fairly inexpensive and very correct, and you can avoid all the hassles associated with restoring yours. After you sell your old parts on Fleabay, you might come out ahead!
