Removing engine
Old Dec 7, 2012 | 10:25 AM
djkocer@gmail.com's Avatar
djkocer@gmail.com
Default Removing engine
Looking for suggestions. 427 big block--Can i remove the motor and transmission as one unit or is it best to seperate them prior to pulling motor out. I do have the radiator, fan, and water pump currently removed. There appears to be lots of room in the front but not sure.
Thx dave
Old Dec 7, 2012 | 10:52 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Pull them together. Don't forget the shifter should come off. Some guys pull the distributor also. You can get extra room by removing the fan shroud if you have one. Dennis
Old Dec 7, 2012 | 10:55 AM
66jack's Avatar
66jack
Take out the Radiator support....it will give you more space....
Make sure you leave the Yoke in, so the trans wont leak on you, the car or garage floor.....
Old Dec 7, 2012 | 11:40 AM
djkocer@gmail.com
Thx guys! Also what is the best way to sucure the engine hoist to the block?
Old Dec 7, 2012 | 01:21 PM
DansYellow66's Avatar
DansYellow66
Old Dec 7, 2012 | 02:37 PM
Bluestripe67
Use grade 8 bolts. If you have a "tilter" just bolt the chains to the rear and front exhaust manifold bolt holes. I don't trust the lift plates that bolt on top of the intake. Dropping a BB makes a terrible sound. If you don't have a tilter, borrow or rent one. It really makes the job a lot easier. Use some string to hold the yoke in. Dennis
Old Dec 7, 2012 | 02:49 PM
midyearvette's Avatar
midyearvette
...i always jerk the dist.
there are times however i leave the trans. in the car
just pull the 4 bolts to the bell, wire up the trans and pull away!....
Old Dec 7, 2012 | 02:58 PM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
For sealing the transmission I used on the these. It works great. Works on the TH350 and the Muncie's.
http://pitstopusa.com/i-5074434-wehr...00-jerico.html
or this one:
http://pitstopusa.com/i-5074435-wehr...50-muncie.html
Old Dec 7, 2012 | 04:49 PM
djkocer@gmail.com
Dennis,
Yoke? Is this where the drive shaft goes into the tranny. Isn't that a sealed bearing. Can't find a rental for the tilt; is it still possible to push down on the tranny to get the tranny and engine up and out.
Dave
Old Dec 7, 2012 | 08:35 PM
Hitch's Avatar
Hitch
No need for a tilter all you need is a piece of chain and the tilter's never work all that well anyway.
Old Dec 7, 2012 | 08:41 PM
jeff batchelor's Avatar
jeff batchelor
Never used a tilter to remove the BB and trans from my car. One man job if you be careful.
Jeff
Old Dec 7, 2012 | 09:31 PM
Bluestripe67
Dennis,
Dave
As said by others, it can be done without a tilter. At least have a couple of friends over for pizza and beer AFTER the engine pull. The yoke is the exact part sticking out of the tailshaft of the trans. Unbolt the front driveshaft u-joint and separate the two. Dennis
Old Dec 8, 2012 | 05:48 AM
aworks's Avatar
aworks
No need to pull the trans unless it needs to come for some reason. I unbolt the bellhousing from the block and just pull the motor.
Pull the rad. and the fan assy. Then hook your eng. hoist how ever you perfer. I use a plate bolted the the carb flange. Hold the motor up with the hoist and unbolt your motor mounts from the block and remove them first. Drop the motor down after mounts are out and that makes unbolting the bellhousing much easier. Support the trans with a jack and pull out the motor.
I do this by myself with no problems. Just dropped a big block in a 69 a few weeks ago.
To Removing engine
