Need Pictures L79 fuel line/fuel pump
Pump to carb so i can use as a cross reference...
and pic of correct pump installed for clocking of inlet/outlet
Received 6,943 Likes
2015 C2 of Year Finalist
Jack best I could do for you
Those pics are okay but not what i need...
I need a picture of the complete line from Pump to Carb...to see the bends in the line.
Received 1,962 Likes
<a href="http://tinypic.com?ref=b96eqh" target="_blank"><img src="http://i50.tinypic.com/b96eqh.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com?ref=2ntlgsg" target="_blank"><img src="http://i50.tinypic.com/2ntlgsg.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
What fuel pump do you have on there and is that a 'real' factory line?
Also...the water pump you have on there, does it have a reducer 1/2 x 3/4 on the bypass connection to the pump
Do you have a pic of the BENDS attached to the pump?
I have a pump similar to that and cannot get my line anywhere close to that..
Jack that is the correct 67 fuel pump. 66 is different yes that's a factory correct repro line. And that's the correct water pump with the correct by pass fitting. I think dad bought that from Bill Mock about 20 years ago
Received 1,857 Likes
Here's the correct '66 #40083 fuel pump, with the inlet and outlet fittings.
A-snake is that the correct PS set up for a L79. doesn't the PS get a 3rd step out pulley on the crank. so it goes captive belt, then alt belt then the PS belt.
(Corrected the pg # for the N40 option)
