I have been reading posted threads on C2 Dash Light conversion to LED's? I read a thread, I can no longer find? It had a Bulb Chart listing each bulb type used in the cluster. There was also a picture of the backside of the cluster with each bulb hole labeled. Can anyone one help me retrive the info?
The more I read on the LED conversion, the more I think new incandesent bulbs are the answer? Any Thoughts?
Its close, but the one I was looking at had the bulb numbers for each application on the leader lines? There was also a chart giving the bulb numbers for each dash application. I am most curious what bulb is used for the ignition switch and the cig lighter? Thanks for your help!
See the bulb chart on page 54 of your owner's manual.
You can also visit the following website that uses a specific vehicle database to show you specifically which LED bulbs correspond to each dash position.
Cig. lighter and ignition switch use #1445 or #53, G 3 1/2 bulb 14.4V .12A, and like all the bulbs in the dash, clock and radio have a miniature bayonet base (BA9S).
Part of the problem is that folks don't correctly title their threads for easier finding later. Somebody who wants specific info on "wiring diagrams for C2 LED light conversion", might just title their thread "1967 Corvette"... or something equally unhelpful.
Rev,
If you go to "Advanced Search" you can search either "Titles" only or "Entire Thread" for key words....takes a little "clicking" around, but it can be done.
Is this it?
Here is the link to the page, very informative, also shows info on each bulb type.
