Distributor Install
Old Dec 19, 2012 | 09:06 PM
riddle24's Avatar
riddle24
Cruising
Default Distributor Install
Recently I have just replaced my vacuum advance on the distributor and now that i have it all back together I cannot seem to get the whole distributor back in. I have the engine already set for the firing of cylinder one and have marked my cap for the drive gear to fall into the oil pump but cannot get it to falll into place. I have been working on this for about a week or so in my shop class and have to stop myself everyday because I get so angry that I feel like I'm going to break something. Anyone got anything to help.
Old Dec 19, 2012 | 09:08 PM
BLee's Avatar
BLee
Take a long screwdriver (over 12") and reach down and turn the slot in the oil pump shaft a little. I had to do that last weekend when I pulled mine out.
Old Dec 19, 2012 | 09:15 PM
riddle24's Avatar
riddle24
Cruising
That's what i have been doing and I adjust for it to spin when it catches the gears vbut won't sit all the way down. The oil pump shaft has some play in it do you think that it could be that?
Old Dec 19, 2012 | 09:44 PM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
There is always a certain amount of play in the pump shaft. I doubt that is your problem. Why don't you just roll the engine over to TDC on the compression stroke and try inserting it again.
Old Dec 19, 2012 | 10:24 PM
63split63's Avatar
63split63
Just push down on the distributor and bump the engine over with the starter . Little bumps , when the slot in the shaft lines up in the dist gear it will drop right in .
Bill
Old Dec 19, 2012 | 10:31 PM
Mike67nv's Avatar
Mike67nv
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
Have you tried following the Chassis Service Manual instructions for installing a distributor? I don’t have a ’66 Manual but in the ‘67 Manual, there are two sections: Installation – Engine Not Disturbed and Installation – Engine Disturbed, located on page 6Y-26. I believe there’s enough detail there to solve your problem.
Old Dec 19, 2012 | 10:39 PM
Dennis Beck's Avatar
Dennis Beck
Bill
Old Dec 19, 2012 | 10:53 PM
riddle24's Avatar
riddle24
Cruising
Bill
You know i brought that up with one of the guys in my class but its an idea that scares me cause i dont want to shred the drive gears, but i think its something i might try now that someone else has brought it up.
Old Dec 20, 2012 | 12:05 AM
LB66383's Avatar
LB66383
If bumping the starter makes you nervous. try turning the engine over by hand with a wrench on the balancer bolt. That's worked for me every time.
Old Dec 20, 2012 | 04:59 AM
alexandervdr's Avatar
alexandervdr
Bill
Not sure what to think about this method (potentially timing could be all wrong if teeth are not engaging correctly and jump when the starter kicks in). My experience is that delicacy (compared to brute force) is usually the better method. I always assume that if brute force is required, something is wrong anyway. One week of trying should have gotten you to at least once when the bottom lip of the distributor fits in the oil pump slot.
I used the method as explained in the book "How-Rebuild-Your-Small-Block-Chevy" http://www.amazon.com/How-Rebuild-Yo.../dp/1557880298. Very well explained, including how to orient the slot in the pump , how to orient the distributor to have correct clearance for vacuum and correct timing etc.
Old Dec 20, 2012 | 07:23 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Bill
Works first time, EVERY time and you don't even have to push down. You can sit in the car and peer through the windshield and see the distributor drop as you bump the starter. Safe and foolproof.
The 13 tooth helical gear on the distributor engages the cam gear before the dizzy is all the way in the slot so timing is not disturbed as the housing drops into place.
Old Dec 20, 2012 | 11:21 AM
Powershift's Avatar
Powershift
When you removed the distributor from the car for repair, did you also remove the drive gear?? If so, make certain that this gear is reinstalled correctly....and not upside down I have seen/heard folks who reversed the gear, and it causes the problem you mentioned.
Also, if you have a factory cam, the dimple in the distributor gear should also point in the direction of the rotor tip.
Checkout BOTH items I mentioned if the gear was removed. If the gear was not removed, then the procedures others have provided above should work for you.
Larry
EDIT: Old thread with similar problem that I mentioned above. http://forums.corvetteforum.com/c3-t...+gear+reversed
Old Dec 21, 2012 | 05:47 PM
wilcar's Avatar
wilcar
Just make sure there is no small piece of something that may have lodged down in the hole. I had this happen to me once and had I taken a second look into the hole with my led flashlight I would have saved myself a tear down thinking there was something wrong with my new cam I had just installed. The debris turned out to be the little black plastic TV cable to carb connector that somehow fell into the dist. hole and was not visible until I got really close to the hole and looked straight down.
To Distributor Install
