Some help needed with C2 VIN
Old Dec 27, 2012 | 04:10 AM
tanfastic's Avatar
tanfastic
Cruising
Default Some help needed with C2 VIN
I've got a VIN and all what I want to know is - the tranny on this car is manual or auto?
Give me a hint here please if someone can.
30867S119731
Old Dec 27, 2012 | 05:24 AM
emccomas's Avatar
emccomas
30867S119731
No way to tell from the VIN. If the engine is original, the engine code will specify HP and manual or auto trans.
You do know this is a salvage car, right...
http://www.google.com/url?sa=t&rct=j...blyO-FwDO3sSBQ
Old Dec 27, 2012 | 05:33 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
30867S119731
To add to what Ed has said............
It's the 19,731 st. Corvette built in 1963.
I looked at the pictures. Looks like a manual trans by the appearance of the gear shift.
Chuck
Old Dec 27, 2012 | 09:09 AM
65GGvert's Avatar
65GGvert
The one in the picture is a 4 speed with a Hurst shifter.
Old Dec 27, 2012 | 10:05 AM
kwkenuf's Avatar
kwkenuf
Clutch pedal visible in photos also.
Chuck Gongloff
IMHO, 41.5K is a LOT of money for that car.
1. You'll get a salvage title which is a "kiss of death" upon resale.
2. You don't know if it is an original motor car or not. That would have bearing on the car's original, pre-damage value.
3. You can't estimate the damage with your eyeballs, i.e. motor full of salt water, trans and rear full of salt water, electrical/wiring issues, etc.
For 41.5K, I think you can do better.
Chuck
Old Dec 27, 2012 | 11:21 AM
RestoMike's Avatar
RestoMike
From: Livin' large and havin' fun in wonderful Oklahoma
Chuck
I'm with Chuck. There are better purchases out there for that kind of money.
Old Dec 27, 2012 | 11:42 AM
Fawndeuce's Avatar
Fawndeuce
Chuck
I believe that the $41.5K is the estimated value before the flood damage Chuck, and the estimated repair is also shown as $41.5K or higher, therefore a write-off.
Bidding is at $16K, you'd sure have to go through it with a fine toothed comb to know what you were getting into...
Then when finished, you'd have to get all the inspections etc. to get the title changed from salvage to rebuilt in order to plate it, if that's even possible on a NJ flood salvage title.
Paul
Old Dec 27, 2012 | 12:43 PM
Chuck Gongloff
Paul
Ah, I missed that part, Paul. I'm obviously not "up" on salvage auctions.
Chuck
Old Dec 28, 2012 | 04:23 AM
tanfastic's Avatar
tanfastic
Cruising
Thanks all for the replies. Clutch pedal - aint it obvious. Have to be more focused.
The car would be travelling to Europe and even for 25k it still can be a bargain, no matter the damage. However, we'll see how the auction go.
Happy new year!
To Some help needed with C2 VIN
