Backwards ammeter
Old Dec 30, 2012 | 02:27 PM
johntony's Avatar
johntony
Cruising
Default Backwards ammeter
Can anybody help with this strange problem? After restoring my '64 coupe, the battery wasn't charging. I had the alternator checked it was OK, but the shop said that the original regulator was bad. They replaced the regulator with a solid state, and it now charges, but my ammeter reads backwards! It shows a discharge to the positive side
of the gage, and vice versa. The regulator plug is on the right terminals. Could it be the new regulator is not right? I hate to get another regulator if that's not the problem. Switching the terminals on the gage does not change anything. It's driving me nuts.
Old Dec 30, 2012 | 02:39 PM
Rich Yanulis's Avatar
Rich Yanulis
Look Here
http://forums.corvetteforum.com/c1-a...he-winter.html
Old Dec 30, 2012 | 04:05 PM
JohnZ's Avatar
JohnZ
Pull the connector off the back of the gauge and use a AAA battery and jumpers (briefly) across the gauge terminals, then reverse the polarity and do it again; you should get equal needle deflection (in different directions) if the gauge is OK. If not, the gauge needs work.
Old Dec 31, 2012 | 01:39 PM
johntony's Avatar
johntony
Cruising
Thanks, JohnZ.
I will try that.
Old Dec 31, 2012 | 02:50 PM
DansYellow66's Avatar
DansYellow66
Mine read backwards after I installed a new wire harness and it only required reversing the leads in the ammeter gage connection as noted.
To Backwards ammeter
