distributor rebuilder ???
Old Dec 30, 2012 | 07:09 PM
tach drive 61's Avatar
tach drive 61
Default distributor rebuilder ???
Its time to rebuild .any good re builders ?? I also noticed in paragon catolog they have two main shafts listed SHP its $185 just for the shaft new bushings are $12 ,then there is the main shaft for all other applications $60 ,Now what would the differance be between each shaft.they also warn of different bushing sizes & check bore sizes . a few years back i did order from corvette central new bushings as well as a new main shaft .the bushings fit the housing I have but the shaft did not fit there bushings it was returned . my unit is a 1112021 350/350 tach drive would this require the SHP shaft ?
Old Dec 30, 2012 | 08:07 PM
jdk971's Avatar
jdk971
get a hold of lars on the forum. he built mine a few years ago. does excellent work. jim
Old Dec 30, 2012 | 08:25 PM
Hitch's Avatar
Hitch
Mike Labudovich in Chesapeake, VA has rebuilt two distributors for my cars in the last few years. He uses a Sun Machine to make sure the curves are set up as needed.
David
Old Dec 30, 2012 | 08:42 PM
bigearl56's Avatar
bigearl56
Default Call Lars
has done two distributors for me and when you get them back its like Ron Popeil "Set it and Forget it"
Seriously he does great work at fair prices with quick turnaround.
v8fastcars@msn.com is e-mail
Earl
Old Dec 30, 2012 | 09:05 PM
Dicecal's Avatar
Dicecal
Earl
Another satisfied customer of Lars!
Old Dec 30, 2012 | 09:09 PM
waltonb123's Avatar
waltonb123
David
Is he on this forum? I'm only a couple miles from there.
Old Dec 30, 2012 | 09:49 PM
Hitch's Avatar
Hitch
Not sure if he is on the CF but he is off Dock Landing Rd and is a great guy to deal with.
Old Dec 30, 2012 | 10:05 PM
waltonb123's Avatar
waltonb123
Is he the service director for Performance Buick?
Old Dec 31, 2012 | 05:33 AM
Hitch's Avatar
Hitch
That's him but he's not at Performance any more.
Old Dec 31, 2012 | 05:17 PM
JohnZ's Avatar
JohnZ
The difference between the two shafts is the shape of the "football" that's brazed to the top end, which works with the weights and springs to determine the centrifugal advance curve. It's very common to have to ream the bushings after installing them in the housing in order to obtain proper shaft fit. The #1112021 was originally on a '70 L-46 (350/350hp), and requires the SHP shaft.
Old Dec 31, 2012 | 10:05 PM
tach drive 61
thanks john looks like the expensive shaft is in the cards ! and lars seems to be recomended here on forum .any PH # for him.
Old Jan 1, 2013 | 01:18 PM
tach drive 61
I managed some research today .looking at my old main shaft pulled from 1112021 350/350 distributor it turned out it was not the shp as should be .so it was most likley replaced long ago the CCW 536 plate was still there . I also noticed a thread warning of shafts sold with football welded on upside down . the good news is corvette central seems to stock the shp main shaft part # 272119 $59 a good price , anyone know why paragon shafts are such a big difference in price.$185
Old Jan 1, 2013 | 01:22 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Have you tried a real auto parts store. FYI that shaft fits more then just that vette. No need to get shafted buying a shaft
Old Jan 1, 2013 | 06:50 PM
tach drive 61
9 times out of ten ask most auto parts stores here for a corvette part and as the world turns comes to mind . my old GM connection is gone , and even back then I would give part #s and watch one guy behind counter have a break down mail order seems way to go these days for a old C1corvette
Old Jan 1, 2013 | 08:26 PM
tach drive 61
well 1st winter project is a go !!! have ordered shp shaft from paragon and it was listed at lower price after all .new bushings ,one shifter boot, and two replacment interior door handles simple stuff ! free shipping with online order. I have made contact with lars he will rebuild distributor thanks again to members for advice.
To distributor rebuilder ???
