split ring battery cable question
Old Jan 6, 2013 | 07:49 PM
myronf's Avatar
myronf
Default split ring battery cable question
I find that the split ring cable fits great on the minus terminal but not on the plus. Seems like the post on the NAPA battery is too large in diameter to allow the ring from the cable to slide down on the post so that some of the post is above the ring. Am I dreaming? If not what can be done to the post? Or what batteries have smaller diameter positive post?
Myron
Old Jan 6, 2013 | 08:00 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
You can buy a battery post cleaning tool by Lisle or maybe NAPA has their own. One end cleans the inside of the cable end, and the other end can scrape the post as you twist it around and around. I would think you could remove enough lead to get you cable to fit securely. Dennis
Old Jan 6, 2013 | 08:06 PM
JohnZ's Avatar
JohnZ
Myron
All batteries have two different diameters of terminal posts, with the positive post being the larger, and the posts are the same diameter on all batteries (it's an industry standard). Are you sure you're not trying to put a negative cable terminal (smallest) on the battery positive (largest) terminal post?
Old Jan 6, 2013 | 08:26 PM
myronf's Avatar
myronf
Dennis: I was thinking the same thing.
JohnZ: Yes I am sure that the cables are not reversed.
Myron
Old Jan 6, 2013 | 08:33 PM
JohnZ's Avatar
JohnZ
Myron
There's such a thing as a Group 24 battery with "reversed" terminals - some '69 Camaros used them; which end of the battery is the positive terminal on when the battery is mounted with the terminals on the rearward side?
Old Jan 7, 2013 | 07:35 AM
myronf's Avatar
myronf
Am I the only one on the forum that has had this problem?
Myron
Old Jan 7, 2013 | 07:38 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I have one of these in my tool box:
http://www.batterymart.com/p-00255-b...FUbf4AodohUAQQ
Old Jan 7, 2013 | 07:50 AM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
Myron, I think what John Z is trying to say is that there should be (two different size cables). One spring end has a larger opening than the other. That is the way mine are. Call Lectric Limited.
Old Jan 7, 2013 | 08:05 AM
MikeM's Avatar
MikeM
Myron
All you gotta' do is squeeze the prongs on the split ring cable with pliers and spread the terminal opening to fit the post. If the prongs are missing, just stick a screwdriver in the cable opening and pry it open a little wider!
This ain't rocket science!
Old Jan 7, 2013 | 08:12 AM
Rich Yanulis's Avatar
Rich Yanulis
I agree with Redbird. Make sure your cable ends are two different sizes.
Old Jan 7, 2013 | 08:13 AM
Frankie the Fink
Army
Which is what I used to do before I got the tool I posted the link to above.
And yes, I've had this problem since about 1965 when I started working on cars.
Never considered it worthy of getting outside help for though.
But to each his own.
Old Jan 7, 2013 | 09:05 AM
rich5962's Avatar
rich5962
I've had similar problems with original and reproduction spring ring terminals. It seems the positive posts on newer batteries are slightly larger diameter than they need to be.
Pic below is a newer Delco battery and a repro cable on a '67. I had to shave the post with a tower type terminal cleaner that Bluestripe spoke of. Then it fit down on the post better, but just about flush.
Just don't spread the spring ring beyond it's limit or you loose some of it's "spring". It's mentioned in the AIMs.
Old Jan 7, 2013 | 01:00 PM
Scott Marzahl's Avatar
Scott Marzahl
I have a new set of lectric limited spring cables and the ground cable is useless, I don't see a way to tighten it up to the new NAPA group 24 battery terminal. It simple slides on and off.
Old Jan 7, 2013 | 02:04 PM
rich5962's Avatar
rich5962
The Brown is the ground cable, right?
Old Jan 7, 2013 | 02:16 PM
Fawndeuce's Avatar
Fawndeuce
Not quite sure if you were asking or telling, but on my '62 the brown cable is the ground.
Paul
Old Jan 7, 2013 | 02:25 PM
rich5962's Avatar
rich5962
Paul
Yes, I was actually asking. The positive cable is black with the bigger diameter terminal and wondering if Scott had the wrong cable on the ground post. If his brown cable doesn't fit tightly it must defective. Maybe they put a bigger terminal on the wrong color cable.
Rich
Old Jan 7, 2013 | 03:36 PM
Scott Marzahl
Thanks guys, I'll double check tonight.
To split ring battery cable question
Old Jan 7, 2013 | 04:10 PM
Ironcross's Avatar
Ironcross
Default There is a Fix
Ignition companies have a lead cap to go over the post...it would take some searching to find them.....there not a high dollar fix and you may try battery companies iie. Interstate or even NAPA that carries Standard {a national ignition brand}....you would probably have to find a 'smart counterman' but they are out there....An ignition buyers guide should show them......as only a store with a large inventory would even have them....they are used for either post, + or -
Old Jan 7, 2013 | 04:24 PM
MikeM's Avatar
MikeM
I had never heard of such a thing so I got curious and did a google. Looks like Advance and O'Reilly both list them.
Search: battery terminal post shim
Old Jan 7, 2013 | 10:33 PM
Ironcross's Avatar
Ironcross
Battery cables at the battery posts are one size not two....the cables will adjust to the post whether positive or negative...Otherwise a cable inventory would almost have to be double in size...and that's not happening........
The shim' thats what I was writing about Mike
