67 throttle spring?
Old Jan 8, 2013 | 06:04 PM
n8ozzy's Avatar
n8ozzy
Default 67 throttle spring?
Hey guys... i will be rebuilding my carb in a few days and have noticed that all the 1967 327's I am seeing have a different spring set up than mine. Is mine wrong? All others I see have the spring attached to the front of the block , and mine is at the back...???
Old Jan 8, 2013 | 06:09 PM
gbvette62's Avatar
gbvette62
The bracket mounts at the front of the manifold, and the spring should run forward to it.
Old Jan 8, 2013 | 06:59 PM
JohnZ's Avatar
JohnZ
It should look like this - 300hp and 350hp are the same, except for iron vs. aluminum intakes - both use the same 3810 carburetor.
To 67 throttle spring?
