speedometer
Old Jan 10, 2013 | 08:37 PM
crovt's Avatar
crovt
3rd Gear
Default speedometer
just bought 66 coupe,327,300hp,all original,tires on knock off wheels. I drove it for 2nd time and noticed speedometer is way off---shows slower than I am going,65mph,tach is at 2500 rpm. Whats the problem and how do i repair ?
Old Jan 10, 2013 | 08:41 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the plastic speedo gear in the trans is wrong. you have to determine what rear gear you have. after you do that. post that here and some one will steer you to the right part.
its a 30 min job at best that anyone could do
Old Jan 10, 2013 | 08:42 PM
JohnZ's Avatar
JohnZ
Most likely has a mis-matched speedo driven gear for the installed axle ratio (PO probably changed the axle and didn't bother to change the speedo gear). What's the axle ratio, and what speedo gear is in it now?
Old Jan 10, 2013 | 08:51 PM
crovt's Avatar
crovt
3rd Gear
Default speedometer
thanks,you guys are great!
To speedometer
