Engine number - 60 vette
Old Jan 18, 2013 | 06:45 PM
cwalley's Avatar
cwalley
Default Engine number - 60 vette
I'm trying to identify information about the engine in my 1960 corvette. I've looked at different posts but I'm still confused. So, what is the best interpretation of F0520GF ?
Old Jan 18, 2013 | 06:52 PM
1snake's Avatar
1snake
Need to know what the casting number is. All that number tells us is that it's a Flint motor built May 20th. The "GF" means it could be a 1955 265, 1957 283 or a 1965 283 none of which were for a Corvette.
Jim
Mike Ward's Avatar
Mike Ward
Built in Flint Michigan on May 20th. Without the casting number and castind date, could be any one of these
GF 1955 265 m/t, 3 spd, a/c - -
GF 1957 283 turglide FI car
GF 1965 283 Powerglide 195hp 2bbl full size
Old Jan 18, 2013 | 07:06 PM
Panama 58's Avatar
Panama 58
In case you need more information, the casting date is on the top side of the block, just under the distributor and ignition shielding. Should be a letter and two numbers.
Panama58
Old Jan 18, 2013 | 07:10 PM
emccomas's Avatar
emccomas
Has to be 65 283 in a passener car. 1955 and 1957 engines did not use a leading zero to represent the month of assembly. A 1955 or 1957 engine stamp would be F520GF.
Old Jan 18, 2013 | 07:21 PM
1snake's Avatar
1snake
Good catch and 100% correct.
Jim
Old Jan 18, 2013 | 07:24 PM
desertpilgrim's Avatar
desertpilgrim
Perhaps it's time to buy an owner's manual, an ST-12 and an NCRS judging manual.
Old Jan 18, 2013 | 07:40 PM
Panama 58's Avatar
Panama 58
Yep. Good catch Ed.
Panama58
Old Jan 18, 2013 | 07:45 PM
Panama 58's Avatar
Panama 58
There is a guy over on the parts for sale forum that has a 283 with casting date of E50 that might work for you if you know your assembly date. He doesn't say what is on the deck. Check your VIN to find the approximate build date. The casting on this engine is May 5, 1960.
Panama58
Old Jan 18, 2013 | 08:07 PM
Mike Ward's Avatar
Mike Ward
How would that help answer the OP's question?
Old Jan 18, 2013 | 08:46 PM
1snake's Avatar
1snake
It wouldn't. That kind of info. is only available to us computer geeks.
Jim
Old Jan 18, 2013 | 09:46 PM
cwalley's Avatar
cwalley
Default Thanks
Thank you all for the great - but disappointing information. Good to know there's such a great resource out there.
Old Jan 19, 2013 | 01:20 PM
emccomas's Avatar
emccomas
And just for clarification, a 1955 engine code would be F55GF, and also have a separate engine sequence number. Good luck on your project, and keep us posted.
To Engine number - 60 vette
