Ls3 conversion bracket kit?
Old Jan 25, 2013 | 05:01 PM
Comp Cam 1's Avatar
Comp Cam 1
Banned Scam/Spammer
Default Ls3 conversion bracket kit?
Hi all that have done this swap. What bracket kit did you use? I am going with a stock frame so would imagine a kit for Alt, Ps, AC etc must be available? Also would think the sanden type compressor would mount on the bottom with the smaller compressor that vintage air sells (however I have seen these on top)? Any sources or part#s would be very much appreciated.
Old Jan 25, 2013 | 05:51 PM
John McGraw's Avatar
John McGraw
For price, it is pretty hard to beat a stock C5 corvette drive setup. You can buy them discounted for about $700, and they include the Alternator, power steering pump and reservoir. For the A/C compressor, I like the street and performance low mount passenger side bracket, as it put the compressor down low, under the engine like the stock LS compressor location. A bunch of guys like the Kwik bracket, but it mounts up top, and I do not like the compressor sitting up on top where it is visible.
There are lost of drives that offer bling, but they all pretty much will exceed $2000.
Regards, John McGraw
Old Jan 25, 2013 | 06:50 PM
Comp Cam 1's Avatar
Comp Cam 1
Banned Scam/Spammer
Thank You! I really appreciate the help!
Old Jan 25, 2013 | 07:09 PM
daz_au's Avatar
daz_au
These days, with GM 430HP LS3 crate motors shipping ready to run, I am surprised one of the corvette vendors hasnt looked at doing a swap kit for the various generation cars.
There has to be a growing market for people wanting a reliable, fast, 30MPG midyear and there are probably a lot of owners sitting on cars with tired old motors that could be pulled across if the kit was well thought out and easy enough to assemble ?
Old Jan 25, 2013 | 07:32 PM
Comp Cam 1's Avatar
Comp Cam 1
Banned Scam/Spammer
Still trying to find the correct lower mount ac bracket! The Holley bracket kit sends the AC up top and without cutting fiberglass not going work due to width of compressor (not an option of course). Someone could make out very well as a vendor selling this in kit form. Still looking.....
Old Jan 25, 2013 | 07:48 PM
1coolC2's Avatar
1coolC2
You can find a complete low mileage used OEM C5/C6 set up cheap if you have some time to look around on the forum and Flea Bay. It's tough to beat them for reliability and function. The lower mounting S&P AC bracket that John mentioned works nice and hides the compressor down low giving the engine bay a cleaner look. Not cheap, but I have no complaints with mine and it's been run under some extreme conditions
Are you sure the Holley mount won't work for you? They now have a mount for the Sanden style compressor and the diagram looked like it would keep it low enough to clear the hood. As far as aftermarket versions, Vintage air front runner is about the nicest out there, but runs over 2K with accessories.
R/
Jeff
Old Jan 25, 2013 | 07:51 PM
LoneStarV's Avatar
LoneStarV
March performance makes a nice set up again you're out 2 grand.
Old Jan 25, 2013 | 10:14 PM
John McGraw
R/
Jeff
Hey Jeff,
Did you pull the OEM tensioner and install a manual tensioner? I had some slippage under acceleration with the A/C on and a stock tensioner. I pulled it and replaced with a Katech manual tensioner, and the belt squealing went away! I would love to be able to drive the A/C off the rear belt position like GM intended, but it just ain't going to happen with the motor mounts where they are.
Old Jan 26, 2013 | 12:12 PM
1coolC2's Avatar
1coolC2
Hey Jeff,
John,
I pitched the factory tensioner on my LS7 from the start and have been running the Katech tensioner with no issues. The factory tensioners will "bounce" and cause belt slippage, or worse, let the belt jump/walk during high rpm operation and rapid rpm changes like auto X racing.
Agreed, I would love to use the seperate belt system as designed, but without some changes to the motor plates, that aint happening. I am still looking at that option though
R/
Jeff
Old Jan 26, 2013 | 12:26 PM
mikem350's Avatar
mikem350
Any problems with oil pans clearing?
What pans fit w no mods?
Old Jan 26, 2013 | 10:41 PM
mikey's Avatar
mikey
I used kwikperformance brackets, but I don't have p/s. With the C2 original chassis, the corvette p/s location doesn't work (interferes with A-arm). The camaro brackets are useable though IIRC.
I'm running an OEM tensioner on the kwikperformance brackets with vintage air and alternator as my only accessories. No issues.
I also used a 4th gen camaro oil pan.
Note, my car is LS2, so not sure how many differences for LS3.
-mike
To Ls3 conversion bracket kit?
