where to pick up mtr.
I Have sent my 427 to the machine shop..all new stuff..and will be broke in and dyno tuned...
Would like to install the mtr( has 3x2)really dont want to take off the top to install it../I could Take carbs and fuel lines off and I have seen those (lift plates) bolted directly to the intake manifold to install mtr..
WOULD any of you do it that way?...seems like alot of weight to rely on a few small bolts into aluminum to pick the entire motor..complet cast Iron mtr built weight must be 630 or so + the fly wheel and clutch...and additional wt. if installed w/ 4 speed tranny...any suggestions or real live work method? or your guess on the wt?
Bluzrocker
Bluzrocker
Received 6,992 Likes
2015 C2 of Year Finalist
there are 7/16 bolt threads on the ends of the heads. use them along with a chain and cross them. works every time
Bluzrocker
Bluzrocker
I just put my L79/trans in my car using the manifold lifting plate...just make sure the plate is 'TIGHT' to the manifold...
