Hi,
My 66' supposidely has a 3:55 rr end and the RED nylon trans gear. When I drive say at 40mph my speedometor reads around 25mph. Please advise whether I have a speedo problem or using the wrong gear???
Thanks, Jerry
Assuming you have a Muncie 4-speed coupled with the 3:55 rear, it looks like you should have a green gear with 22 teeth. Red would have 21 teeth. How sure are you about the rear gears? If you see "AA" stamped on the underside of the rear, you have 3:55. If it's "AM" it's 3:36. Dennis
A 3.55 axle with stock tires takes a 21-tooth red speedo driven gear. Check the number of driveshaft revolutions it takes to turn the rear wheels one turn and verify the axle ratio.
Hi Bill,
Don't know lowest. Are you suggesting I go to a lower tooth gear?? If so about how many # of teeth do you suggest?
Jerry
it's a Bubba-ish solution, but an inexpensive one to try. but changing the speedo gear will also change the odometer reading; how correct is your odometer now? find a road with mile markers and check it before doing anything else.
Bill
welllll.... there is no doubt that the speedometer assembly has a problem... now, what do we do.... if the speedometer is otherwise functioning, (no needle bounce or inconsistent speed readings), then Bubba says you try a different gear. how many teeth on that red gear? 21? you can get a 17, 18, 19 & 20 tooth gear; the less teeth the higher the speedo will read; a reasonable rule of thumb might be that for every tooth less you will pick up 5% in speedo speed... but the math seems to indicate that might only be worth 5mph max.
if that is the case, then an inline ratio adapter will make bigger adjustments... if you don't care about the odometer not working; here is my suggestion: call these people and tell them you want to pick up 15mph and see what they suggest in a ratio adapter (and you can always fine tune it by changing driven gears.
