Fill plug leaking
Old Feb 24, 2013 | 03:47 PM
vettepoor's Avatar
vettepoor
Active Streak: 90 Days
Default Fill plug leaking
What do you recommend to stop a leak on my 57's rear differential fill plug? It doesn't have any type of gasket, and I don't want to overtighten it. Not a bad leak, more of a nuisance.
Old Feb 24, 2013 | 03:58 PM
jtranger's Avatar
jtranger
The Corvette suppliers have a gasket for the plug. The fluid should not come out when you take the plug out. The fluid should be just below the hole when you put your finger in there.
Old Feb 24, 2013 | 04:06 PM
vettepoor's Avatar
vettepoor
Thanks for the info. I know the rear is not over-filled, this is something that just recently started. I will chase down a gasket.
Old Feb 24, 2013 | 07:42 PM
jdk971's Avatar
jdk971
isn't there a air intake at the top. some are plastic and some are metal. to relieve pressure.
i could be very wrong. jim
To Fill plug leaking
