Flat vs. Roller
Bill
retro conversions, not better luck than a FT. Just wishful thinking that a roller will last longer or be trouble free. Some roller lifters last only 2000 miles. But, those make a heck of a lot of power!
if you go hydraulic, wear is a lot minimal or non existent in most cases.....
Solid rollers aren't meant for street type stop go, long idle periods typical of a true street use. They are designed for very steep ramp race type cam profiles. Spring rates requirements are high on these style camshafts also. You can use them on the street with a very good maintanence schedule but even then it isn't optimal.
Hyd rollers are on almost every car made today. Retro fit roller lifters and camshafts come in many types and styles. They get a bad rap for falling flat at the upper rpm ranges specifically on BBC with large heavy valves, however with a good lifter higher rpms can be achieved. If that is what you are going for. The key is proper selection of components.
I have had all the different types of lifters and camshafts on my motors. I just built a 496 for the 66 and I used a hyd roller with Morel hyd roller lifters that were specifically designed for 6600+ rpm, I used titanium spring retainers and matched the springs to the cam and lifters.
People who make blanket statements and recomendations without knowing the specific facts are clueless and are making a judgment on something without all the information. Which is what happened on a cam selection thread the other day.
First figure out what you would like the motor to perform like and then select the components to do what you want. I will say this I'll never use another flat tappet camshaft ever again. Just remember the first wiped out flat tappet camshaft you have pays for your roller lifter conversion.
Have a few hun on some Crower severe duty solid rollers its on the street all the time. So far so good. I idle it at 1200 partly for splash partly as thecam is pretty healthy.
Keep up on the lash. Im only running a 210-220 lb spring and a not so aggressive ramp so it shold last a long long time.
Or the trick thing to do would be to use a larger dia lifter so the load is spread out more on the lifter. Grind cam accordingly , thats gonna get done on my next one makes sense.
Using rollers with EDM holes for oiling is best as the lube is injected directly into the roller bearings. I install standpipes in the drainback holes in the lifter valley when I do these installations. Splash oiling is not needed here, and this greatly reduces windage on the crank. The use of a rev kit keeps the lifters in contact with the lobes and eliminates shock loads on the needle bearings. "Milder" solid rollers don't use exceedingly non-compliant springs, and if beehives are used, that's better still. Pressures in the vicinity of 150/400 psi allow revs well past 8000 RPM.
I'm no expert but I will share my own personal experience. I ran a solid roller in my drag car and bought what I was told were the best roller lifters I could buy - Isky RedZones. I ran these for years, hundreds of passes and no problems.
I sold the car to a guy who drives it on the street (it's a 9 second car). He's been driving it without issue.
My sample size is as small as you can get, but I wouldn't hesitate to go roller. I would just make damn sure you are buying quality parts and that the heads are set up with the right spring pressure and the pushrod length is correct.
Good luck, I'm subscribing I want to see what others say.
So, do you want to be the fastest kid on the block and spend hundreds and hundreds of $$$$$$$ on all this hot rod stuff that may break anyway or is the stock performance, lumpy idle and OEM long term durability right for you for $150 or so for stock replacement?
With the better cam profiles available for rollers (more lift for a given duration) I will never build a flat tappet motor again.
Had a quality crane solid roller lifter come apart on my 540 BBC in my boat - engine came as a solid with the boat - had maybe 3 seasons on it, and never saw more than around 5,200rpm. I changed it over to hydraulic rollers, and that was 7 years ago. I'll probably never use a solid roller again, unless I built an all out, short lifespan, drag strip only engine.....
A good example of the difference between flat and roller hydraulic lifters can be found when you look at the peak power rpm, and the overall power curve of the ZZ4 crate motor, at 355hp/408lbs vs the old LT1 of 70 at 370hp/380lbs. The modern roller motor made basically the same power, but with peak hp at 800 rpm lower, 5,200 vs 6,000. The cam duration is so low on the ZZ4 it idles smooth, while the Lt-1 was rather large at an advertised 317/346, and had a rough idle. One of the magazines did a comparison on these motors a few years back, and the LT-1, built to 1970 specs, came within 5hp of it's orig rating if I remember correctly. The ZZ4 is 10:1 compression, vs 11:1 for the LT1. Both motors would probably run the same times in the same car, but one would be shifting at 5,600-5,700 rpm, and the other would probably be shifting at 6,500 rpm... One would be fine with 3:55 gears, while the other would be begging for 4:11's....
Yup, they use melonized steel distributor gears, but that's only when using the more radical solid rollers which MUST use a steel blank for durability.
If the geometry is set right (pushrods) and you use high quality parts, you have a much stronger motor which is more durable than a flat tappet engine. It's also wise to reinforce your sheet metal timing cover by brazing sheet steel to the inside, where the button contacts it.
There is nothing new or modern about this. All this has been common knowledge for years, ever since roller cams became available to SB/BB Chevies and other engines over 50 years ago.
There is no question the roller cam will make more power tahn a flat tappet in any performance engine. There is also no question that any attempt to even get close to a roller profile with a flat tappet cam will probably result in super stiff valve springs, bent pushrods and rounded off cams and less power. The biggest problem with retro fitting a roller cam is the COST!
In the meantime, there are plenty of old guys like myself that don't have to burn rubber for two blocks and just like the sound of the original stuff and the performance characteristics (what's wrong with a 4.11?
) that will last forever as long as the valve train is all matched to OEM levels.It costs a lot of money to retro an older engine and go with a bullet proof roller cam, roller rocker setup and related components. And then there's the "while I'm at it" mode you get into when you realized your stock heads are NOW the big choke point in the power of your engine so you get to spend another $1K to take care of that little problem.
Is it really worth it? Your choice!
It wasn't tuned in perfectly in this video, but it shows that it still has plenty of lump.
The problem with solid rollers is that the rollers are not turning at the time the roller surface comes into contact with the cam lobe, i.e., at the end of the lash period. This gives the opportunity to pound the needle bearings slightly flat, causing their eventual failure. A couple of CF members using solid rollers consider them a "maintenance item" as in they get thrown away and replaced at regular intervals to avoid a catastrophic failure.None of this applies to hydraulic rollers. They are always in loaded contact with the cam lobe so there is no pounding the needle bearings flat because the bearings are always turning. If you go hydraulic roller, consider a "rev kit" which is a set of additional springs placed in the valley that force the lifter bodies into contact with the cam lobes, but do not affect the part of the lifter that moves the pushrod. That way you can run sane valve spring pressures while avoiding valve float. Too much spring pressure at the head will cause even the best hydraulic lifters to partially collapse, resulting in valve float below the rated RPM of the cam.
