MSD Atomic FI
I have been researching a few of these 'wet flow' throttle body EFI kits and there are some 'gotchas'. Here are a few:
1) If you aren't running an electronic 'triggering' device for your distributor then you won't have a clean enough tachometer signal in most cases for the EFI to operate properly - meaning you will need to add an MSD 6 or MSD 6AL box if you don't already have one. Some HEI dizzys can work but not all.
2) The appealing 'returnless' external electronic fuel pump system will only operate in the most optimal conditions you can imagine. Meaning you will almost surely need an 'in tank' electronic fuel pump with a return line. MSD has a 'scoring' system to help you determine if you can use the returnless pump and very few conditions will allow it.
Even if you do put the pump in the tank - on certain cars with shallow tanks (such as my '67 Chevelle) folks have quickly found out that you can starve out the system on hard launches or sharp turns with less than 1/2 tank of gas.
3) You will need an extra temperature sending unit port somewhere if you want to run BOTH the EFI and a temperature gauge - some cars may have them; but some may not.
4) If you choose the 'fuel only' approach (meaning the EFI controller does not regulate the cars timing) then you are getting only partial benefit of the system. If you DO want to regulate timing then you have to already have, or purchase and install, an electronic system such as the MSD 'ready to run' distributor or the like.
5) You are still prone to suffering the vagaries of fuel distribution just like with a carburetor since you are still injecting the fuel into an intake manifold and not individual cylinders as in modern EFI 'rail-based' systems.
You can easily dump $3K into one of these setups and potentially be not much better
off than if you calibrate and 'dial in' a good carb setup.
FTF
FTF
Bill
... when i was 'tuning' my EFI there were MANY times i wanted to find a tall building and jump off....which makes me wonder how these are supposed to constantly self-tune and adjust...
Bill
They all suffer from pretty much the same shortcomings. Do some research and see what folks with some actual miles on these kits are saying. They can be made to work but require more effort than the hype and media blitz would have you believe and are not a cheap alternative to carbureation.
For example, I bought the PowerJection III kit and it is junk. I was almost 3K into that POS and it never really did much better than the 750 Holley I had on the car. I had a nice 383 stroker, AFI heads, healthy cam, 500+hp and it ran rather poorly compared to the carb. The customer support was limited at best...mostly not helpful. The linkage was mechanical, same as my Holley, and had slop in it, so the timing of the throttle body opening wasn't precise and caused hiccups with the software and dorked up the a/f ratios. The software wasn't at all setup to account for other than sea level tuning, (I am at 7k ft) which required a bunch of math on my part to account for power loss, etc...made tuning nearly impossible. I can continue but I will spare you...
If I was going to do another EFI, I would do something like the Edelbrock system which has its own intake, fuel rails, injector for each cylinder, etc...this is much closer to a modern LS setup than a throttle body carb style system.
I am not bitter over wasting good money on such a folly
...hell, with the money I pissed away, I could have been half way to a fresh LS3 crate engine...oh, not to mention the hours I spent installing, fabbing fuel lines, fittings, electrical, etc.Good times...
Frank
'65 Corvette - Edelbrock 350 Performer crate engine
'75 Silverado - Original 350 SBC
'80 Baja boat - Original Mercruiser 260hp
I can see benefits of an EFI swap in each case, but right now I'm holding back - something I expect many of us are doing. It's a matter of priorities, money and time/hassle associated.
A body-off chassis restoration/preservation, body strip and repaint for both the Corvette and Silverado are imminent (within the next 5 years, with the truck first as it's already begun.) After working on the boat on-and-off for the past six years, the boat's body and trailer have been completely redone and soon as the new floor is 'glassed in this spring - it's going in the water for summer.
As for the EFI - all vehicles are currently running well enough - so I can wait for the options to further play out in the field. LS swaps become more common and EFI retrofits are becoming more field-tested, so the price and hassle can only drop.
I attended an MSD tech seminar on their Atomic product when it was launched last year, and to me it looks to be currently the most promising - but I left fairly certain I'd need to do a return line on my tank in the Corvette. After all, a return line is the proper way, but it does open up a new can of worms. If I do either the EFI retrofit or LS swap as part of my larger body-off plans, I'll be able to get to all the associated electrical and fuel line issues.
In the meantime, I'm going to be very interested reading about everyone else's experience with choosing an EFI retrofit or LS swap, and looking very closely at the so-equipped Corvettes and Trucks at Carlisle!
On balance, these systems over-promise and under-deliver and I, for one, am going to stay away from them.
2 guys are active members here on the forum, Gerry mossy66 and Roy (67-427ci). I know Roy had tried other efis that didn't work out but seemed pleased with the atomic system.
Maybe they will chime in.
Jeff
My point is, they put the atomic systems on right before the trip and headed out. I was skeptical but after seeing the units perform trouble free for over a combined 15000 miles on 3 different engines If I was thinking about that type system I would not hesitate.
But I will be sticking with my tuned port for now.
Jeff
This is the setup in my 62 Corvette.
I modified a 2 1/16" Hilborn 8 stack injector to EFI for less then $4000.00
My goal was to keep it from looking "electronic".
Notice there are NO fuel rails.
and 1 fuel line feeding the fuel distribution block (looks like the old barrel valve).
Worked out pretty cool. See attached picture. Ignore the 2 different types of stacks, trying different ones.
We plumbed a plenum under the intake to get vacuum from all 8 runners and use MAP for fuel control along with the other sensor inputs.
Megasquirt ECU and relay box, GM 32 pound injectors, O2, Incoming air temp, water temp, throttle position sensor.
DIY self tune software and it runs great.
I'm controlling fuel only but have capability for ignition control, nitrous, boost plus lots more,
[IMG]http://i1094.photobucket.com/albums/i459/ohiovet
/57%20Gasser/005.jpg[/IMG]
Frank
I agree. I too tried the powerjection on a car a few years ago and i have never been so frustrated in my life. I attempted to tune the car for 8 months, spent 600 taking it to the dyno, and finally pulled it off and sold it for half the initial price. What a nightmare! It ran, but not well and depending on if the stars were aligned correctly, it might start. I was stranded due to that system more than once. Every time i see a set up like it brings back bad memories and I cringe. The only one i have used in the past that actually worked as advertised was the mass-flo efi system, but it had a few small hiccups. However, it ran well and made the car enjoyable, but was it worth the money over a carburetor??? probably not.
Bill
