Throttle return spring question
Old Mar 5, 2013 | 12:37 AM
turbo's Avatar
turbo
Default Throttle return spring question
I have a 65 Vette 300 hp with the correct Carter afb. I'm trying to find out where does the throttle return spring attach to at the carb. I don't see a separate hole for the spring on the throttle arm? Does it just go over the linkage? Anyone have a pic of it. Thanks
Old Mar 5, 2013 | 01:52 AM
65GGvert's Avatar
65GGvert
The large curved end of the spring goes through the small hole drilled in the part of the throttle linkage that goes through the lever on the side of the carb. There's also a washer between the spring and the bushing that goes in the lever hole where it pivots. It looks like a hole for a cotter pin, but that's where the spring goes.
If that's not clear, I can get a picture tomorrow.
Old Mar 5, 2013 | 09:57 AM
turbo's Avatar
turbo
Yes, a picture would help
Old Mar 5, 2013 | 11:26 AM
65GGvert's Avatar
65GGvert
Here's a picture. I'm running two springs, so it distorts the bushing a little. I should probably add a washer.
Old Mar 5, 2013 | 11:46 AM
LB66383's Avatar
LB66383
You could always hook the second spring to the lower arm shown in that photo, and run it toward the back of the engine. It's easy to make up a bracket to hook it to,
Old Mar 5, 2013 | 01:59 PM
JohnZ's Avatar
JohnZ
It's designed with the spring going to the front for a reason; if you run a spring to the rear, it accelerates wear on the throttle shaft and its hole in the baseplate.
Old Mar 5, 2013 | 03:09 PM
rick charles's Avatar
rick charles
Default 1965
by the looks of the throttle linkage distourtion i would say sping tention is a big factor . try taking off one spring and let it relax .
Old Mar 5, 2013 | 04:30 PM
65GGvert's Avatar
65GGvert
I'm not having a problem, I posted the picture to show the OP where the spring attached. Whether one spring or two, the rod pulls as shown. The additional spring is as a safety and does not add much tension in the relaxed position shown in the picture. I need to add a washer to the inside between the bushing and the spring end, just haven't done it yet.
Old Mar 5, 2013 | 07:43 PM
Tom454's Avatar
Tom454
Running them to the rear, as is factory on many engines, causes premature wear of the throttle body and throttle shaft. This is one of the common repairs I have done in the past for forum members.
Old Mar 5, 2013 | 08:26 PM
turbo's Avatar
turbo
Thanks for the picture. I'll go hook it up the correct way now.
Old Mar 6, 2013 | 12:02 AM
LB66383's Avatar
LB66383
You should ALWAYS run two throttle return springs. Just one spring isn't safe.
To Throttle return spring question
