windshield date code
Old Mar 6, 2013 | 07:29 PM
KCSLED's Avatar
KCSLED
Default windshield date code
I need to order a dated windshield for my 67,the build date is 11-14-66.Does anyone have a idea what the proper date should be on the glass? KC
Old Mar 6, 2013 | 08:09 PM
Dave Kitch's Avatar
Dave Kitch
NCRS allows 1 year time frame on date for glass so window could be date coded for Nov 65 to Nov 66. Typically, a windshield is manufactured 1-3 months prior to car build date Look at your 67 judging manual for the proper codes.
Dave K.
Old Mar 6, 2013 | 08:27 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
What is the date on the windshield now or other glass in the car
Old Mar 6, 2013 | 08:44 PM
6T5RUSH's Avatar
6T5RUSH
Cruise-In III Veteran
I just went through this date code thing with my '65. My car's birthday is tomorrow, March 8. When I spoke with Pilkington, they stated typically 4 months prior to the assembly date. A check of my side glass (my windshield had been replaced with a non-dated glass), shows the driver's vent window is LOF, then Safety Plate, then ASZ on the left, then CG P on the right, followed by Safety Tempered. The CG is the LOF Date Code for:
C=November and G= 1964 & 1977
So, my March, 1965 assembled Corvette had original date coded glass 4 months prior to its assembly on the car.
When I order the glass from Pilkington, I requested a November, 1964 date of CG.
Hope this helps.
Jim
In God We Trust!
Old Mar 6, 2013 | 09:12 PM
Dave Kitch's Avatar
Dave Kitch
Dave K.
If you are worried about the date code than you must be interested in getting the car NCRS judged? If so buy a 67 Judging Manual and see what it says. My 66 manual says windshields are typically date coded 1-3 mo. prior to car build date but 1 year prior to build date is accepted. Your car will be judged against the manual and glass is covered in detail in the manual. My 66 was built on 12/20/65 so I date coded the windshield for Nov 65.
Dave K.
Master Judge (65-66)
200 points
Old Mar 7, 2013 | 06:54 AM
mhanley's Avatar
mhanley
Hope this helps.
Jim
In God We Trust!
Jim,
The Nov date won't be a problem, I would go with it. You have up to one year.
Mike
To windshield date code
