Wheel offset / backspace
Old Jun 17, 2002 | 11:56 PM
kenmo's Avatar
kenmo
Default Wheel offset / backspace
In the many wheel posts here I see some folks refer to wheel offset. Others backspace. They are one and the same, aren't they ?
Old Jun 18, 2002 | 12:05 AM
SWCDuke's Avatar
SWCDuke
Default Re: Wheel offset / backspace (kenmo)
No. Backspace is the distance between the inside face of the wheel and the mounting plane of the wheel. Offset is the distance between the "center" of the wheel as measured by half the distance between the inside and outside face or the wheel or half the width of the bead flanges AND the mounting plane of the wheel.
Offsets typically are in the range of -0.5" and +0.5". Backspace is in the range of half the overall width of the wheel.
Duke
Old Jun 18, 2002 | 07:15 PM
bcwaller's Avatar
bcwaller
C2 of Year Finalist (performance mods) 2019
Default Re: Wheel offset / backspace (SWCDuke)
In case a picture helps, check out this site for diagrams and tables to help with offset and backspace calculations http://www.rsracing.com/tech-wheel.html
To Wheel offset / backspace
