Hard Top ID
Old Mar 19, 2013 | 10:16 PM
Jymmeye's Avatar
Jymmeye
Default Hard Top ID
I bought a hard top for my 63 many years ago. I did not know what year it was from because it fit and at the time that was all I was interested in. The back plexiglas has since spider webbed pretty bad so I would like to put a new window in. Are all years the same or will I need to find out the specific year? Is there something on the window that will tell me the year? Thanks for any help I can get.
Old Mar 19, 2013 | 10:18 PM
wombvette's Avatar
wombvette
There should be a date code in the window, but as for shape, they are all the same.
Old Mar 20, 2013 | 08:10 AM
kingwoodvette's Avatar
kingwoodvette
What is the sequence on the date code? Thanks.
Old Mar 20, 2013 | 08:49 AM
ifitgoesfast's Avatar
ifitgoesfast
IIRC, there's also a date on the fiberglass underneath the headliner (I think). Can't recall if it was ink or stamped.
Old Mar 20, 2013 | 09:01 AM
wombvette's Avatar
wombvette
Two letter code. A-L Jan to Dec and a year code. 66-F, 67-G
I don't remember 63-64 year codes.
Old Mar 20, 2013 | 10:27 AM
kingwoodvette
Thanks. Unable to find a date code on my 63 HT, must be a replacement.
Old Mar 20, 2013 | 11:10 AM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
It could be original and the code hidden by the window seal.
Old Mar 20, 2013 | 12:05 PM
provette67's Avatar
provette67
I have never seen the stamping covered by a seal. Here is an example of one a '67 top
Old Mar 20, 2013 | 12:49 PM
tuxnharley's Avatar
tuxnharley
According to Noland Adams book on page 113 - "early '63 hardtops had an interference problem with the top rear corner of the door. Later tops, after 12-4-62, had a cutaway to provide extra clearance".
He lists several running changes made during the '63 model year in trim and brackets, such as rear widow inside trim originally being two piece but later changed to three, and a rear window reinforcing bracket being added.
It may be possible to identify if your top is a '63 by checking these items.
Old Mar 21, 2013 | 10:35 PM
Jymmeye's Avatar
Jymmeye
I just went and checked my window, and it has the same exact code as the one posted by provette67. How do you decode those numbers. Do all of the windows have the same codes?
Old Mar 21, 2013 | 11:47 PM
Mike67nv's Avatar
Mike67nv
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
Hardtop rear window date coding varied over the years for midyears (63-67). The date code in the above picture translates the “J” (lower left) = October, and the “F” (upper right) = 1966. So, the Plexiglas in the picture was manufactured October 1966.
Old Mar 22, 2013 | 08:34 AM
macs65's Avatar
macs65
I bought a hardtop several years ago that was off a 67, covered in vinyl. During resteration of the top I noticed a number punched into the frame under the area where the weather strips fit. Can't remember the exact location, but I think it was bottom of the sail panel. The number was was very difficult to see.
Old Mar 22, 2013 | 08:53 AM
kingwoodvette
Tuxnharley: have 3 piece molding and rear glass support. You mention a cutout for additional clearence; how would I recognize this?
Old Mar 22, 2013 | 09:12 AM
ifitgoesfast
It would be on the bottom corner (which points to the door handles); a slight cut to clear that upper corner of the area, maybe about 1/3 of an inch higher than the rest of the bottom line, to the rear of the stainless steel trim piece behind the side window.
Old Mar 22, 2013 | 09:16 AM
provette67's Avatar
provette67
The date codes are not all the same
Old Mar 22, 2013 | 09:25 AM
ifitgoesfast
Here, this is a rough drawing (Adobe Illustrator) I just did approximating it, see arrow
Old Mar 22, 2013 | 11:17 AM
kingwoodvette
Thanks for the drawing. Looks like mine has a very small relief , 1/8" or less in this area. Seems smaller than you suggest. Perhaps someone way back did a little "field adjustment"
To Hard Top ID
Old Mar 22, 2013 | 11:30 AM
ifitgoesfast
My drawing might've exaggerated how much cut out, but that's basically where it should be.
Old Mar 22, 2013 | 01:11 PM
Mike67nv's Avatar
Mike67nv
Here's a pic of a notched '63 top:
Old Mar 22, 2013 | 01:15 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Here's a pic of the so called 63 HT notch.
Also, here's a pic of the date code on a 63 HT.
My eyes aren't as good as they used to be, and the pic is blurry, but you can see that the 63 HT's are dated in the format M-YY, This one looks like 7 63.
Chuck
