I just found a big scratch on my 66. Anybody have a source for touch up paint??? Can't seem to get it through any of the catalogs I've seen. HELP!!! :mad
dcxguy
Try "paintscratch.com". They sell 1/2oz. and 2oz. bottles, and 12.5oz spray cans of touchup paint for most cars from 1952 to present. I purchased a 1/2oz. bottle of #988 Molboro Maroon and it matched my paint very well.
CUL Jim
You could also try going to a good paint/restoration shop. I just had some work done on my '67, and they gave me some additional paint. They mixed it themselves to match mine, and did an excellent job. Getting OTC paint that claims to be the same color as yours may not blend so well. Getting paint from someone who mixes it to match yours might be an easier way to go. Might not be cheap though!
7vettes
You're right, not cheap, but it's the only place I've found that supplies small amounts of paint for our old cars.
If you're fixing scratches, check out http://www.langka.com
CUL JIm
I have had good results using the Chip Kit from Pro Motorccar Products in MI. The kit has these tiny Pro Touch brushes which apply and lift off paint allowing you to fill the chip over time the more time the better. It has a fiberglass brush which cleans out the scratch if rust would be problem and #2000 wet sanding paper, ultra fine polish compund a small rubber sanding block and some clear coat. The instructions are very detailed and I have made undetectible chip repairs with this system. promotorcarproducts.com 1-800-33GAUGE
