Idle issues
You have to be careful not to drop any hardware. I use a special captive screwdriver that holds the screw.
Thanks for the opinions and advice. I will let y'all know after I take the car on a good run.
MikeC
MikeC
You need to measure your manifold vacuum using a gauge to see what you need. Manifold vac at idle on this L71 was 14"Hg. The MS163-16 needs 18"Hg to fully deploy. The B26 needs 12"Hg to fully deploy, thus the 2" rule satisfied. If you just switch to manifold vacuum using the 163 it will likely have unstable/no effects at idle.
MS 163-16: 0* @ 9", 16* @ 18"Hg
B20/B26 (VC-1765) 0* @ 6", 16* @12"Hg
The purpose of switching to manifold vac is to allow timing to be fully advanced at idle so you need to use the correct adv can. You will also need to ensure your static timing is set to spec, and likely have to adjust fuel mixture and idle.
Personally, I would take a few points hit on 2 configuration issues, but have a better performing engine especially through Operations testing. Bigger hits in Ops.
Rich
http://www.camaros.org/pdf/timing101.pdf
UPC K19 A7 View A shows it going to the choke signal tap with a Tee which is manifold vacuum. That's where I sourced the vacuum for the vacuum advance on the L71 I restored a few years ago.
Rich
Measure the manifold vacuum at idle and use a vacuum can that is fully deployed when vac drops to 2 in-hg below idle vacuum.
It's all been said before earlier in this thread.
Non-HEI Distributors:
P/N ID# Application Starts @ “Hg Max Adv
(Distr. Degrees @ “Hg.)
VC1802 B22 1971-72 350 4-bbl 7-9 8 @ 14-16
VC1765 B26 1965 396 Impala High Perf 5-7 8 @ 11-13
or 1966-67 Corvette Exc. High Perf.
B20 1966-67 Impala 427 Exc. High Perf.
1966-68 327 Powerglide Exc. High Perf.
1969 307 All
1969-70 396, 427 Camaro, Chevelle High Perf.
1970 400 2-bbl
1970 307 MT
1973 Camaro 350 High Perf.
VC1810 B28 1965 409 High Perf. 3-5 8 @ 5.75-8
1965 327 High Perf.
1966 327 High Perf.
1964-67 Corvette High Perf. FI
VC680 B1 1959 – 63 All Chevrolet 8-11 8 @ 16-18
1964 Corvette exc. FI
1964 Impala, Chevy II
1965 396 High Perf.
1965-67 283, 409
1966-68 327 exc. Powerglide
1967-68 All 396
1969 Corvette 427 High Perf.
1969 396 Exc. High Perf.
1969 Corvette 350 TI
1969-70 302 Camaro
1970 400 4-bbl
1970 396 High Perf.
1970 Corvette 350 High Perf.
1973-74 454 Exc. HEI
VC1605 B9 1965 impala 396 Exc. High Perf. 7-9 10.3 @ 16-18
1965 327 All Exc. FI
1969 327 Camaro, Chevelle, Impala
1969-70 Corvette 350 Exc. High Perf.
1969-70 350 4-bbl Premium Fuel
1970 350 Camaro, Chevelle, Impala High Perf.
1971-72 350 2-bbl AT
1971-72 307 All
VC1675 B13 1968 327 Camaro Powerglide 9-11 8 @ 16-18
1968 327 Impala AT
1968 307 AT
1968 302, 307, 327, 350 Camaro, Chevy II
1970 350 Camaro, Chevelle Exc. High Perf.
VC1760 B19 1969 350 Camaro, Chevelle, Impala 4-bbl 5.5-8 12 @ 14-18
1969-70 350 2-bbl
VC1801 B21 1971 350 2-bbl 7-9 10 @ 16-18
1971-72 400, 402
1971-72 307 AT
Other Part Numbers & Specs:
VC700 B3 8-10 11.5 @ 19-21
VC1415 M1 6-8 10 @ 13-15
VC1420 M2 5-7 11 @ 16-17
VC1650 B12 8-10 10 @ 15-17
VC1725 B18 8-10 12 @ 13-16
VC1740 A5 6-8 12 @ 15-17.5
VC1755 A7 8-10 12.5 @ 18-20.5
VC1804 B24 6.5-8.5 10 @ 12-14
VC1805 M13 6-8 12 @ 14.5-15.5
VC1807 B25 5-7 8 @ 13-15
VC1808 B26 5-7 8 @ 11-13
(The 1808 part number has been discontinued by Echlin. It is the same as part number VC1765)
VC1809 B27 5-7 9 @ 10-12
VC1812 B30 5-7 12 @ 11.75-14
I went through a exercise to do exactly that a few years ago and with help from many others it proved to be the best solution. It was a noticeable difference and the car could sit at idle for long periods of time and ran consistently under 190 degrees. The B26 was a perfect match with 14"Hg vacuum on the L71 I worked on.
The document below by Lars and Duke is very helpful information.
Rich
Base timing (VAC plugged) at 5* @ 800 rpm gives me 15" Hg
With manifold vacuum I get 23* @ 800 rpm with 17.5" Hg
Idle speed set to 850rpm. Total idle timing 24 degrees (8 initial, 16 vacuum)manifold vacuum at idle speed = 17"
With this setup the car runs great. The idle is smooth and steady even after running hard for 75 minutes. I have fixed my issue. Thank you to all that helped and provided solutions along the way.
MikeC.
MikeC.
