Transmission help.
Old Apr 5, 2013 | 05:26 PM
ohiovet's Avatar
ohiovet
2016 C1 of Year Finalist
Default Transmission help.
A friend with a 59 with a T10 is having shifting problems.
The transmission is a fresh rebuild.
With the car not moving and running you can shift through the gears without any problems. Pretty much the same with the engine stopped.
When moving, the shift from 1st to 2nd needs to be done gently, the 2nd to 3rd shift is also difficult.
The linkage has been properly adjusted.
Any thoughts or things to try?
Thanks,
Bruce B
Old Apr 5, 2013 | 05:54 PM
1restoman1's Avatar
1restoman1
Veteran: Coast Guard
2023 C1 of the Year Finalist - Modified
Sounds like your not getting full release of the clutch. Check all of the adjustments and look for warn linkage, bent clutch fork, worn pivot ball etc.
Old Apr 5, 2013 | 06:14 PM
W Guy's Avatar
W Guy
Does it grind when going into reverse?
Verne
Old Apr 5, 2013 | 08:46 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
Not all rebuilds are done correctly. I had one rebuilt and it would grind in 3rd gear every time. I eventually brought it to someone else.
Old Apr 7, 2013 | 10:13 PM
ohiovet's Avatar
ohiovet
Thanks for the input.
We went back and adjusted the clutch, checked and adjusted the shift linkage and went out for a drive.
The shifting was still not good but I was troubled more by transmission noise.
2nd and 3rd gear under acceleration whined very loud.
When you let off the gas the noise stopped.
Shifting was still not very good , had to double clutch a few times to get it in gear.
Another strange thing was that at one point the trans would not shift out of second gear, I tried everything but it would not move. When I shut off the engine it shifted out of 2nd very easily.
I think it's time to pull the trans, any thoughts?
Old Apr 8, 2013 | 07:40 AM
plaidside's Avatar
plaidside
Was a new clutch put in at the same time?
What oil are you using?
Joe
Old Apr 8, 2013 | 08:27 AM
SledgeHammer 2.0's Avatar
SledgeHammer 2.0
Thanks,
Bruce B
IF you can shift it pretty easy sitting still with the clutch in, the clutch is working fine. Usually when the clutch is the issue, it will be harder than heck sitting still, engine running, and be easier while moving.
Like John said, not all rebuilds are done right and if it's making a loud noise, stop now and fix what's wrong before you do more damage.
and for the obvious question, you did fill it up with gear oil? I worked at a standard only shop for years when I was younger, I can't tell you how many failed units came back because they didn't put oil in them.
Old Apr 8, 2013 | 09:07 AM
ohiovet's Avatar
ohiovet
Guys,
Good points and questions.
The clutch was put in recently and it is adjusted properly.
No grinding when putting it in reverse(engine running) or first & second but difficult shift into 3rd and 4th.
The trans was rebuilt by a reliable guy , but I did not check the trans lube, sooo it might not be present. I'll call my friend shortly and find out if it has lube in it.
Thanks again.
Bruce B.
Joe,
I read your instructions on transmission rebuilding and it is great, so I appreciate your input along with others comments.
Bruce
To Transmission help.
