Alternator help please
Connect a voltmeter across the battery terminals - engine off should read 12.6V with a fully-charged battery; with the engine running at 1200-1500 rpm, it should read 13.8-14.2V if the system is charging.
Wiggle and push on the plug on the inboard 8-way multiple connector on the engine side of the fuse block to see if that brings the battery gauge to life. Both wires to the battery gauge (black and black/white) go through that connector, and if the connector isn't fully seated or the terminals are corroded, you won't see any indication on the gauge needle.
Do you have a wiring diagram that shows where the "ammeter" senses the difference in voltages? And did you check for voltage at those two points, or at the ammeter connector plug behind the dash?
When the car is running at >2,000 RPM, what is the voltage on the red wire at the alternator and at the horn relay, and what is the voltage at the battery?
The horn relay is the junction. The "big red wire" is the regulated voltage output from the alternator. If, as you said, you are getting 12V at the battery and junction with the engine running, you are not getting the expected approx 14V out of the alternator. If we assume the alternator and regulator are good, you need to do the following:
1. Check the voltage at the alternator between the output terminal and ground with the engine running. If it is 14V, there is a problem with the connection to the junction. Check continuity (resistance) between the alternator end and the horn relay end.
2. If there was not 14V, there is a problem with the regulator wiring.
- Check the ground of the regulator. Test continuity between the radiator support and the metal base of the regulator.
- Check continuity of each of the wires between the plug at the alternator and the voltage regulator. There are 3 - F-F, R-2, and gnd. Then check the continuity between the voltage regulator and the horn relay (3).
- Finally, make sure all of the connectors are clean making good contact at the alternator plug, the regulator and the horn relay.
Greg
- A couple of additional notes:
1. How it works: (very simplified). When you turn the key on and the engine is not running, 12V is applied to the #4 terminal which then feeds 12V to the alternator F terminal to create an initial field to get the alternator output going when you crank over the car. Once the alternator output as sensed on the R terminal gets to about 3.2V, the regulator begins regulating the field current (F terminal) by opening and closing the regulator points based on the sensed voltage from the horn relay junction via regulator terminal 3. The rapid opening and closing of the points results in voltage being regulated at about 14V. The voltage at the alternator output will be a bit higher depending on the current draw.
2. If any "add-on" accessories are connected somewhere else than at the horn relay junction (like directly at the battery), it can make the ammeter not work at all.
