I could not take it any more. It's late April, the weather sucks (snow showers today!) and I took the 65 327-300 roadster out for the first time since I pulled the engine 1 yr ago for rebuild. With the engine out I cleaned up the engine compartment and redid the whole front suspension. First stop was a wheel alignment $350!!??? I feel I was raped but it's done. Took him 2.8 hrs. Next stop was a 40 mile run.
The following things happened:
Engine ran great
Steered great (for an old car)
braked great
On the negative side:
The glove box kept popping open
The new quartz clock died
The glove box courtesy light quit. - same circuit as clock?
And my tach needle started bouncing around towards the end of the ride.
Also the cable seemed to squeal when shifting. I know that I am guilty of a fairly tight cable bend at the distributor.
Oh yeah-for awhile the ammeter was reading about 15 amps plus, the oil pressure was very high (I think the engine builder put in a high volume pumpand 20 w50 and the water temp was low (160F thermostat)
Congrats on getting on the road, you will continue to feel better.
Adjust the striker on the glove box.
Clock and light not sure about.
Tack cable casing may need to be cleaned out and relubed.
The tach cable should not be at a sharp angle. I think your distributor is off a tooth.
What was the hi pressure reading. A hi pressure pump and tight bearing clearances couples with 20w/50 will give you hi pressure.
The water temp is good.
Drive it some more and watch the numbers carefully. Go back and check all the hose clamps, valve cover bolts (don't tighten them too much is you have stamped steel covers) and other bolts. Dennis
My '65 300hp motor had 70# of oil pressure after the rebuild.
Always bugged me that the needle was off the scale.
Did a bunch of research and found this is common with Melling pumps because even standard M55's are often equipped with the pink high pressure relief spring. Set to open at 70#.
I found that there is a yellow 58# spring, as well as a green 49# spring. This is Melling.
Swapped mine out for the yellow and life is good. No more pegged oil pressure needle.
The 70# spring is a good choice for solid lifter motors with the 80# gauge, in my opinion.
I prefer a 180 or 190 Degree Thermostat with a newer engine. The higher settings will not cause overheating as long as cooling system is operating correctly. My reasoning is, as time goes by you will be able to go back to a lower Temp Therm to tighten the engine back, by lowering operating Temp.. Al W.
You shouldn't have ANY bend - re-install the distrbutor correctly and the cable fitting will point directly at the grommet hole in the firewall.
