c2 headlight adjusyment HELP
I had both headlight buckets out in order to paint the car. They are now back in and all hooked up. Everything works except one closes perfectly and the other does not. I think I have the Y stop misaligned. Is it possible to change that Y stop without taking everything apart? If so any suggestions would be helpful.
Sure, just reach under there with a 7/16" wrench and adjust the stop bolts. If the close stop is wrong, then the open stop will probably be wrong as well. The Y stop has about 4 splines that you can set it on, so you almost always have to adjust, if you miss the spline it was on before.
This is a job that should have been done before mounting the motors, but you can still do it, you will just have to roll the motors up and down, until you get it right.
Regards, John McGraw
St. Jude Donor '05, '09, '15
Tom
