my instrument panel lights on my 64 are not as bright as I think they should be. I do have the brightness control tuned up all the way on the light switch. Does anyone have an idea for correcting this?
...maybe old bulbs or incorrect, lower wattage...can't just use the bulbs off the card in the local parts supply, they're re lower wattage...install 1816's
When I removed mine, they had been in there so long that a heavy coating of dust had accumulated on them. You'll be surprised how bright they are when cleaned. Also, as posted above, using the correct bulb helps.
...yeah, just had a problem with my running lights and the bulb was caked in with corrosion and damn near opaque with dust...on the cluster, remember that you need the "winker" bulb for the headlights (and parking brake also if i remember correctly) - not cheap (# 257)
