350hp Decal Problems...
Old May 10, 2013 | 08:23 PM
66jack's Avatar
66jack
Default 350hp Decal Problems...
Its not that hard to put them on.
But, how come the Decal keeps flaking off before i even get the valve covers put on the car, what am I doing wrong....
3RD SET...
I'll fill you all in later on the engine problems...they multiplied from the oil leak...
Old May 10, 2013 | 10:51 PM
Tmichaelson's Avatar
Tmichaelson
Made sure to clean valve covers correctly prior to 350 decal placement and my decals did the same thing. Someone tell us why???
Old May 10, 2013 | 11:14 PM
VetteRed1965's Avatar
VetteRed1965
Use denatured acohol from your local hardware store to clean prior to application
Old May 11, 2013 | 10:42 AM
Dicecal's Avatar
Dicecal
Use these instead:
https://www.paragoncorvette.com/p-35...it-350-hp.aspx
Old May 11, 2013 | 11:54 AM
66jack's Avatar
66jack
Originally Posted by Dicecal
Whats the difference:
http://www.parts123.com/parts123/yb....Z5Z5Z50000050B
Old May 11, 2013 | 12:08 PM
gbvette62's Avatar
gbvette62
Stop in your local hobby shop, or model train store, and pick up some "decal setting solution".
Decal setting solution allows a decal to stretch, and conform to the surface it's applied too. It was created for model railroading and model kit builders, to help get decals to conform to a model's surface irregularities, such as wood grain, rivets, body lines, etc.
You lay your decal down, and spread the setting solution over the decal. The setting solution will cause the decal to conform to the valve covers surface (especially the "porous" surface of aluminum covers), eliminating air bubbles, silvering, etc. Setting solution also helps bond the decal to the covers.
You can also use setting solution, to ease the removal of old decals. Because it's designed to soften the decal, if you spread it over old decals, and let it sit a few minutes, it softens the decal enough to remove it easily.
There are a number of different brands of setting solutions. I've always liked "Solvaset" and Microscale's "Micro Set", but it's also available from Badger ( the airbrush company) and Testors.
Old May 11, 2013 | 12:10 PM
Dicecal's Avatar
Dicecal
Originally Posted by 66jack
Valve cover horsepower decal kit, 350 h.p. Includes (2) mylar replacement decals.
Years: 1965 - 1966
Vs
Valve cover horsepower decal kit, 350 H.P. Includes (2) water soluble decals.
Old May 11, 2013 | 01:17 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Didn't the 350 HP motor come with cast script valve covers? The decal goes below the fins?
My choice would be the mylar decals, but i am not looking for points. I never cared much for water decals, I always broke them, but i didn't know about decal solutions at the time
Doug
Old May 11, 2013 | 03:49 PM
mcb55-210's Avatar
mcb55-210
Great info-never heard of it before.
Thank you.
Mike
To 350hp Decal Problems...
