Question for JohnZ
Old May 11, 2013 | 09:05 PM
GA67Terp's Avatar
GA67Terp
Default Question for JohnZ
John:
As you always seem to know the answer to my questions, I thought I would run this one by you.
On my 62 300HP there are 2 holes drilled in the firewall to the left and below the heater input box that are approx. 4 inches apart and appear to be factory drilled. They are roughly 3/8" to 1/2" in diameter. Do you have any idea if they are supposed to be there and, if so, what they may have accommodated?
Thanks as always....
George
Old May 11, 2013 | 09:54 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
Originally Posted by GA67Terp
John:
As you always seem to know the answer to my questions...
Ehem, John doesn't seem to know anything, he knows.
Dan
Old May 11, 2013 | 10:46 PM
Hitch's Avatar
Hitch
Why not just email or IM him?
Old May 11, 2013 | 11:36 PM
GA67Terp's Avatar
GA67Terp
I stand corrected on the "seems"
And the IM is a good suggestion
Thanks guys
Old May 12, 2013 | 12:43 PM
00fxd's Avatar
00fxd
'cause if the answer is posted here someone else may want to know as well
Old May 12, 2013 | 03:27 PM
62Jeff's Avatar
62Jeff
George
On my restored 62, below the firewall seam and to the passenger side of the heater box opening, are 2 holes 5" apart.
Those holes are penetrated by rubber male-shaped firewall insulation retainers.
There is a similar hole and rubber retainer to the driver's side of the heater box opening, near the verticle ignition shielding.
Old May 12, 2013 | 05:02 PM
GA67Terp's Avatar
GA67Terp
62Jeff:
Thanks for your response. Seems like the most logical answer and since mine are open I will check for the insulation that should be in the area behind the firewall.
Old May 12, 2013 | 05:19 PM
62Jeff's Avatar
62Jeff
62Jeff:
You can see the insulation in this photo. One of the retainers is visible just above the carpet line to the right
Old May 12, 2013 | 07:36 PM
JohnZ's Avatar
JohnZ
I defer to "62Jeff" and "62Corvette" when it comes to '62 detail issues.
To Question for JohnZ
