Remove/replace fuel pump 1963
Old May 12, 2013 | 09:58 PM
B-52's Avatar
B-52
Default Remove/replace fuel pump 1963
I need to replace the fuel pump on my '63 SHP. The rear bolt looks to very difficult to reach. I haven't tried but it looks like removing the wheel and going in through the upper control arm opening may work.
Any suggestions would be appreciated!
Old May 12, 2013 | 10:50 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
You nailed it. That's the easiest way to do the job.
Old May 13, 2013 | 01:27 AM
Dave64's Avatar
Dave64
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
Just a couple long extensions on the ratchet and you'll have it out in no time...'course, putting it back in won't be as easy. Make sure to get the pump rod positioned in the 'up' position and held in place with a bolt before you remove it.
Dave
To Remove/replace fuel pump 1963
