Passenger door won't open
I own a '67 coupe and I can no longer open the passenger door, either from the inside or the outside. The key turns the lock button on the inside, but the door latch appears to be the issue. Does anyone have any suggestions to get the door to open?
Thanks for your help in advance.
I " think" I remember that it happened to someone else on the Forum and he had to take the door panel off with the door closed ( which is probably not a simple job) and operate the lock mechanism by hand.
THIS MIGHT HELP...Even though its the Driver side latch its a mirror of P side....
http://forums.corvetteforum.com/c1-a...tch-fixed.html
OR THIS ONE..
http://forums.corvetteforum.com/c1-a...om-inside.html
OR THIS ONE..
Received 6,978 Likes
2015 C2 of Year Finalist
Take a good flash light and look down inside the door and see if you can see any of the rods that go to the latch.
