K-H wheels casting date decoding?
Old May 14, 2013 | 10:22 AM
mallie's Avatar
mallie
Default K-H wheels casting date decoding?
Got a 1965 coupe with original K-H knock-off wheels. The casting date on the wheels says "A4 28 66", I assume it means Arpil 28 1966. Not sure what A stands for. So that means the car did not come with those wheels, there were added later.
Old May 14, 2013 | 10:37 AM
5thvet's Avatar
5thvet
Yes, they were definitely added later with the April 66 dating. The "A", I believe, stands for work shift.
Old May 14, 2013 | 10:43 AM
mallie's Avatar
mallie
So if car did not come with k/o wheels, wheels hubs/adapter needed to be changed for the k/o wheels??? Unless car did come with k/o wheels but they were changed later on for whatever reason....
Old May 14, 2013 | 10:55 AM
5thvet's Avatar
5thvet
Yes, but it is nearly impossible to figure out what it came with originally. In 67, they started with a tank sticker on the gas tank which listed all of the options but no such luck in 65. The option code for knock offs in 65 was P48 but I am not sure whether that can be traced back to an ECL code on the trim tag. Perhaps someone else will know.
Don
Old May 14, 2013 | 11:00 AM
mallie's Avatar
mallie
Don
ECL won't tell you about most options. Decoded my ECL and it tells me car came with powered windows opptions (which it has), that's it. Only way to know for sure would be window sticker or build sheet, which I dont have of course...
MY question is if car came with rally wheels instead of k/o wheels, are there any change required (wheel hubs/adapter?) to put on k/o wheels?
Matt
Old May 14, 2013 | 11:33 AM
5thvet's Avatar
5thvet
Matt,
Yes, for real knock off, there are adapters that are added which are side specific. I believe they bolt on using the lug nuts.
Don
Old May 14, 2013 | 11:37 AM
desertpilgrim's Avatar
desertpilgrim
Lets be kind and just say that the person(s) doing the date stampings at K-H on KO wheels were REQUIRED to be bi-polar. Some of the variations seen on obviously original wheels simply defy logical interpretation. I'm sure that someone, somewhere has a truly
beautiful page from K-H describing the procedure and how it should be done. Unfortunately, that page never made it to the guy on the line.
Old May 14, 2013 | 11:45 AM
tuxnharley's Avatar
tuxnharley
Matt
Your first post said your car is a 1965. 1965 Corvettes did not come with rally wheels; those were not introduced until 1967. A 1965 would have had plain steel wheels and wheel covers as standard equipment.
Old May 14, 2013 | 02:26 PM
JohnZ's Avatar
JohnZ
Matt
NO. The basic chassis didn't care which wheels it got - hubs/spindles/lug studs didn't change. If it got steel wheels, they bolted on with lug nuts. If it got KO wheels, the adapters bolted on (with longer lug nuts), and the KO wheels secured to the adapters via the spinners.
Old May 14, 2013 | 05:05 PM
mallie's Avatar
mallie
Sorry, meant plain steel wheels I guess.
JohnZ answered my question.
Thanks,
Matt
Old May 14, 2013 | 05:22 PM
midstyle's Avatar
midstyle
Originally Posted by JohnZ
..... If it got KO wheels, the adapters bolted on (with longer lug nuts), and the KO wheels secured to the adapters via the spinners.
Here's a shot of the adapter, long nuts and spinner that John refers to.
a
Old May 15, 2013 | 11:34 AM
63Corvette's Avatar
63Corvette
a
Um, looks like your rear anti-sway bar may be a little loose there.........
To K-H wheels casting date decoding?
