1967 info
Old May 21, 2013 | 11:05 AM
Neil Baker's Avatar
Neil Baker
Default 1967 info
[B[/B] Anyone (JohnZ) know where I can find build sheet info for a 1967 Vert VIN# 194677s116661 ?? I know the St. Lewis factory burned and the build sheet may or may not be on the gas tank. Looking for info before going through taking the tank out. Any help will be greatly appreciated.
Old May 21, 2013 | 11:22 AM
5thvet's Avatar
5thvet
If it is not on your tank I think you are out of luck unfortunately.
Old May 21, 2013 | 11:39 AM
67's's Avatar
67's
Most times you can move the rubber boot out of the way, to see if it is there. Otherwise, it is probably gone for ever.
Old May 21, 2013 | 12:29 PM
jprop's Avatar
jprop
I agree. I was able to see mine by pushing the boot out of the way. However, you will not be able to safely remove it without dropping the tank.
To 1967 info
