Tachometer Cable Question
Old May 25, 2013 | 07:07 AM
1050rayvette's Avatar
1050rayvette
Default Tachometer Cable Question
Just installed a new tach cable on my 64 and my wuestion for you Gurus is this.
Because of the location and difficulty of attaching the cable to both the dash and the distributor, is there a chance the cable ends are not seated correctly and could possibly cause premature cable failure?
I have everything attached and working fine....just concerned that since I could not see or feel that the ends were seated correctly that I might have screw up! Thanks in advance.
Old May 25, 2013 | 08:07 AM
EDinPA's Avatar
EDinPA
If you try hard, you should be able to see if the threaded end is all the way on. I was just putting this back on yesterday on a '66, unless they are not the same.
