Door Window bolt measurements on 66 coupe
Can anyone advise the outer lower door widow track bolt measurements from the indentation on the rear outside of the door. I had door restored and holes are covered.
Bolt
I believe they are 1/4-20. If the bolt hole is covered, you must have the tracks out of the car, so try it first. The fastner is actually a phillips head bolt. Jerry
