Windshield washer not pumping
Old Jun 25, 2002 | 01:40 PM
boerio's Avatar
boerio
Default Windshield washer not pumping
The mechanism sounds like it's working, but just not sucking the fluid through the tube. The tubes aren't clogged, as I can run fluid through them. Any ideas on things I can try to get the fluid from the jar to my windshield?
- Jeff
Old Jun 25, 2002 | 01:45 PM
JohnZ's Avatar
JohnZ
Default Re: Windshield washer not pumping (boerio)
Once they run dry, they need a good "prime" to get them going again; fill the hose from the jar to the pump and keep trying (blow the hose out first to make sure it isn't kinked or clogged).
Old Jun 25, 2002 | 01:56 PM
boerio's Avatar
boerio
Default Re: Windshield washer not pumping (JohnZ)
Yeah, I blew the line out, then took a water bottle and sucked water through the line and attached it. Still didn't send fluid out (after several attempts). I suppose the lines from the pump to the nozzles could could be clogged, and it looks like an interesting proposition to get those dealt with.
- Jeff
Old Jun 25, 2002 | 05:39 PM
7vettes's Avatar
7vettes
From: If I say it's safe to surf this beach ......then it's safe to surf this beach
How long has this been going on......did they suddenly quit after regular use, or is this the first time you've tried them in 2-yrs, etc?
Old Jun 25, 2002 | 05:40 PM
boerio's Avatar
boerio
Default Re: Windshield washer not pumping (7vettes)
It's the first time I've tried the washer since purchasing the car in December.
- Jeff
Old Jun 25, 2002 | 05:59 PM
7vettes's Avatar
7vettes
Have you tried holding a finger over the end of the hose to feel for suction? If you don't get it at the hose, try the fitting at the pump.
Old Jun 25, 2002 | 06:08 PM
boerio's Avatar
boerio
That's a good idea. I'll try that this evening.
- Jeff
To Windshield washer not pumping
