Decipher CE Block Stamp
Where did the "512" guess come from?
In looking at CE engine typical stampings reference material, I see the following assignments:
1st character = Chevrolet
2nd character = Engine
3rd character = assembly year
4th to last chars = a) 00,001 - 19,999 = Flint L6 engine
..........................b) 20,000 - 49,999 = Flint V8 serial numbers
..........................c) 50,000 - 79,999 = Tonowanda serial numbers
This stamping seems to be at odds with typical ones that I have been able to find.
Last edited by 65tripleblack; Jun 18, 2013 at 11:29 AM. Reason: Error in 4th to last character reference
In looking at CE engine typical stampings, I see the following assignments:
4th to last chars = a) 00000 - 49999 = Tonowanda serial numbers
..........................b) 50000 - 99999 = Flint serial numbers
CE4A20001 would signify
Flint V8 number 30,000
They would have had to produce 420,000-plus Flint V8 replacement engines in the year in question (if no characters were skipped), in order to arrive at "N".
..........................c) 50,000 - 79,999 = Tonowanda serial numbers.
When they ran out of numbers in their originally assigned block of numbers for any year, they were supposed to add an "A" after the year of manufacture digit and start the number sequence again (and Flint V-8 got another block of 10,000 numbers, from 90,000-99,999).
This got too complicated, apparently, and the "standard format" began to fade away around 1973, and the "supplemental format" became random.
All the "CE" number will tell you is that the short block was replaced and the year it was made, and there's no way to tell what the innards are unless you tear it down.
