wiper problem
Old Jun 18, 2013 | 10:05 PM
65 Dave's Avatar
65 Dave
Navigator
Default wiper problem
1965 c-2 wiper tested per Willcox u-tube it checks out good , but you remove the test ground it should "park" , but it does the park 2times before it stops. Any help ? Whom does a good job rebuilding?
Old Jun 18, 2013 | 11:45 PM
rwerth7's Avatar
rwerth7
Dried up grease in the gears appears to be a primary reason for not parking. Remove the cover to the gears, clean out the old grease with WD40 and add new grease. Good luck
