Small block heads advice.
Old Jun 24, 2013 | 09:24 PM
Bobonthis's Avatar
Bobonthis
Default Small block heads advice.
I'm looking for advice on what is a good set of roller rockers, 3/8" screw in studs, guide plates & good push rods if someone could help. These go on a set of 2.02 small block heads. They are also 1.5.
Old Jun 24, 2013 | 10:22 PM
Hitch's Avatar
Hitch
Comp Cam Pro Mags.... You may have to double up on the valve cover gaskets though because of the poly locks. If you want to avoid that you can purchase shorter poly locks or have the ones provided machined.
Hitch
Old Jun 25, 2013 | 11:13 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
I've found the Comp Cams roller tipped rockers to be very satisfactory if your max valve spring force is less than ~325#.
Old Jun 25, 2013 | 11:45 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
What's the intended purpose of the engine for which you want these parts?
Old Jun 25, 2013 | 05:30 PM
macs65's Avatar
macs65
Hitch
had mine machined to fit the stock covers,
Old Jun 25, 2013 | 09:24 PM
Bobonthis's Avatar
Bobonthis
I'm putting a 350 engine into 1967 corvette and are looking for around 350 to 375hp and want it for driving.
Old Jun 25, 2013 | 09:33 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
If that's all you're looking for then stick with the roller tip rockers ! You don't need anything more.
Old Jun 25, 2013 | 11:36 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
I would suggest good old stock Chev stamped rockers for your HP range. Unless you want bragging rights about roller rockers
I can't remember if the best ones had the triangle or O stamped in them, I am sure someone can remind me, but if you can find those used, go for it, or just buy some true 1.5 stamped rockers from Crower, or someplace.
Less to go wrong, utterly reliable, less expensive,and no valve cover clearance issues.
Doug
Old Jun 26, 2013 | 07:52 AM
jim lockwood
Given your application, I agree with Doug on this.... keep it simple and use the stamped steel rockers. See that car in my avatar? Per vintage road racing rules here on the left coast, it runs stamped rockers (low dollar replacements I bought at NAPA). Never a problem.
You also asked about rocker studs and push rods: No one does it better than ARP for rocker studs. My car uses Comp Cams "Hi Tech" push rods. Never a problem with either of these.
Jim
Old Jun 27, 2013 | 10:06 AM
Bobonthis's Avatar
Bobonthis
Thanks to all who have posted - that is what I thought as well. I'll be getting them ordered soon...............
To Small block heads advice.
