aluminum heads
aluminum heads
want to put aluminum heads on 427 that was rebulit 23 years ago ??
Received 6,547 Likes
C2 of Year Finalist (track prepared) 2019
What is your question?
Would there be a problem seeing how the motor has 40,000 miles on it.or do i just do the motor again??
St. Jude Donor '07
what heads you use is independent of the mileage on the engine. if you were satified with the way the engine ran/runs (compression/oil consumption/oil pressure/etc), just swap heads.
Bill
Bill
BB heads come in open and closed chamber and even the open chamber have several different volumes. What do you have on it now - original closed chamber iron heads? You will need to match them reasonably closely to avoid a significant compression ratio change. Going to aluminum makes higher compression engines more forgiving of today's gasoline so you don't really want to give up much if any compression.
Received 3,043 Likes
St. Jude Donor '05
Sure why not drop some weight and performance at the same time
And no it wont blow your bottom end out before that myth surfaces again.
