No Start
Old Jun 30, 2013 | 06:28 PM
myronf's Avatar
myronf
Default No Start
Beautiful day here in WI. I drove the 65 small block yesterday and today. In the last 2 days, when I would turn the key for a hot start there would be a 1 or 2 second lag, and then the engine would turn over and start. Cranking would be at normal speed.
Decided to take my wife for a ride this afternoon. The engine was warm from 2 hrs earlier.
I turned the key - nothing. No click. The ammeter read approx (-20 amps) Tried this about three times and then decided to take another car. I think that I was the only non convertible car on the the road!!
What do you think?
Myron
Old Jun 30, 2013 | 06:48 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
What do you think?
Myron
Sounds like your starter solenoid bit the dust.
RON
Old Jun 30, 2013 | 08:01 PM
myronf's Avatar
myronf
Would you say that the solenoid could be heat sensitive? The car sat and cooled for about 3 hours. I just went out there, and as I suspected it started right up.
Old Jun 30, 2013 | 08:11 PM
Hitch's Avatar
Hitch
When I hear any car not starting with no click I think of the starter. As the starter bearings wear or begin to fail it can allow the windings to short on the case. Much like and engine a motor will usually stop in the same location when rotating to a stop. A lot of times you can take a hammer and wack the starter and it will jarr it enough to allow you to start the car / truck.
In midyear cars the main power wire that goes through the firewall can cause a similar problem. Over the years the power wire heats and cools expanding the contact area and allows the wire to no longer connect properly. Next time you have the problem wiggle the firewall wiring connection and see if the car will start. If no then lay up under the car and wack the starter with a hammer.
Starters are cheap I would replace the starter first and go from there.
Hitch
Old Jun 30, 2013 | 08:49 PM
myronf's Avatar
myronf
I was thinking that I would try to cool the solenoid with water. If that worked, replace the solenoid. If not, then cool the starter. By the way, the solenoid is 500 mi old, and the original matching numbers starter was professionally rebuilt at the same time.
Comments?
Old Jun 30, 2013 | 08:55 PM
Hitch's Avatar
Hitch
I would spend $50 bucks on new auto parts store starter and see if that resolves the problem. If so send the numbers matching starter back out for rebuild and live happily ever after..
Hitch
Old Jun 30, 2013 | 09:11 PM
GreaseMonkey's Avatar
GreaseMonkey
PA Events Coordinator
Hitch
Old Jun 30, 2013 | 09:12 PM
56Heap's Avatar
56Heap
First verify that the solenoid is getting juice when you turn the key. The main harness connection at firewall is a typical trouble spot.
Old Jun 30, 2013 | 09:30 PM
65GGvert's Avatar
65GGvert
I had the same issue two years ago. Ammeter reading full negative, no sound. After cooling it was fine. I replaced the solenoid and have had no issues starting since. I think it was around $20 bucks at O'reilly's with lifetime guarantee.
To No Start
