Engine Number
The engine number is 105422 F0601CQ. From what I can tell this means the car was produced in January 1961 and the motor was built June 1.
Did the engine stay in inventory from June 1960 to January 1961? It seems a long time for a motor to sit unless they used a FIFO system.
Jim
F0601CQ, indicates that your engine was built at Flint (F), on June 1st (0601), and that it's a base 283/230. Six months prior to the car's build date, is considered possible, and is the limit excepted by the NCRS. The engine you have, appears to have been built more than 8 months prior, to when the car was. I'm not going to say that it's not possible, but it's highly unlikely.
What's the casting date of the block, as well as the casting number? This info would be helpful in determining the correctness of your engine. The casting date is located on the bellhousing flange, on the right rear (passenger side) of the block. The casting number is in the same area, on the left.
The date will be in the form of a letter for the month, one or two digits for the day, and a single digit for the year. As an example, a block cast on June 1, 1960, would have a casting date of F10. The casting number should be 3756519. Some very late 61's used the 3789935 block, but the 935 wasn't being cast in 1960.
0601, would either be June 1, 1961, or June 1st, 1960. Engine casting date should be interesting.
Doug
Unfortunately, I'm away from the car and can't confirm my notes.
I've been worried about that 8 month gap...
Stamper: There, finished, looks pretty good.
Buddy: hey, your numbers are backward.
Stamper: Oh, F@#&, well, maybe nobody will notice, too hard to deck block again.
Doug
It won't lessen my enjoyment of the car since I'm not pursuing NCRS dreams, but it certainly affects the value.
Thanks everyone.
