Headlight aiming
Old Jul 7, 2013 | 08:52 AM
RatDog's Avatar
RatDog
St. Jude Donor '20 thru '25
Default Headlight aiming
I need to get my headlights aimed/adjusted. High beams are OK but low beams are aimed too far down. I called up a Tire Kingdom store thinking that might be a place to get this done and was told I need to find a place that has the equipment to do the "old school" headlight aiming.
"Back in the day" you could get this done most anywhere.
Any suggestions?
Old Jul 7, 2013 | 09:03 AM
VetteRed1965's Avatar
VetteRed1965
I used a parking lot at the local high school and shot the head lights on a wall to align mine, the flatter the parking lot the better.The outside frame needs to be removed. Be careful when adjusting the screws the alignment bracket is plastic.
After raising them go drive a while and see if they are your liking.
I could not get mine high enough. I check the voltage to the head lights and i twas only getting 11.2 volts. I installed a relay kit to bring the voltage up to 12.7 and it made the a big difference. Lectric limited sells the kit. Its an easy install. I did both the high and low beam head light relays.
Old Jul 7, 2013 | 09:33 AM
1snake's Avatar
1snake
The factory service manual spells out exactly how to do it yourself. IIRC, you park your car on flat ground 30' from a wall and adjust then according to the chart in the manual.
Jim
Old Jul 7, 2013 | 09:36 AM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
....it's in the manual, and it's easy if the adjuster screws are free.
Old Jul 7, 2013 | 10:20 AM
RatDog's Avatar
RatDog
I have the "1967 Chassis Service Manual". Is that a different book than the Factory Service Manual? My book gives instructions on aiming the headlights using a "T-3 Safety Aimer" that apparently fastens to the headlights with a suction cup.
Since my lights are aimed low, when I get my car back home I'm going to take a look at the buckets to make sure they're opening as far as they should.
Thanks,
-- Steve
Old Jul 7, 2013 | 10:59 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Don't you have any old time shops that are not chain stores
Old Jul 7, 2013 | 11:15 AM
RatDog's Avatar
RatDog
Someone told me to check with body shops, especially ones that have been around for awhile. I think that's what I'll do.
-- Steve
Old Jul 7, 2013 | 11:18 AM
Nowhere Man
-- Steve
They will have them.
Old Jul 7, 2013 | 11:22 AM
sixtysixtom's Avatar
sixtysixtom
First make sure headlight buckets open all the way, one of mine was lower so I removed the hood and made the adjustment, and replaced the hood, two people, half hour job. Then I adjust them against my garage door, using the horizontal line as the horizon. Works well.
Tom
Old Jul 7, 2013 | 11:25 AM
62Jeff's Avatar
62Jeff
Thanks,
-- Steve
Since your high beams are OK, the headlight bucket movement is not going to be the full solution.
Old Jul 7, 2013 | 11:32 AM
RatDog's Avatar
RatDog
You're right! Obviously, I haven't thought this through very well <LOL>.
Thanks,
-- Steve
Old Jul 7, 2013 | 04:59 PM
JohnZ's Avatar
JohnZ
Back in the day, in the plant we used Hopkins Aimers.
Old Jul 7, 2013 | 05:33 PM
RatDog's Avatar
RatDog
That's pretty cool, John.
Do you know if that's what they used at dealer service departments, too?
-- Steve
Old Jul 7, 2013 | 06:42 PM
JohnZ's Avatar
JohnZ
-- Steve
Yes - garden variety precision Hopkins Aimers with ring adapters for the T-3 lamps; part of the basic equipment package for every GM dealer in those days.
Old Jul 7, 2013 | 06:52 PM
1snake's Avatar
1snake
Thanks,
-- Steve
If you don't want to spend money on a piece of equipment you'll only use once, PM me your e-mail address and I'll sent you a copy of the instructions/diagram from the 1963 service manual showing how to do the "Aiming Screen Method".
Jim
Old Jul 7, 2013 | 07:02 PM
Mike67nv's Avatar
Mike67nv
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
If you’re interested in trying it yourself, here’s a link to a visual procedure I have used in the past. It’s not that hard to do and you should be satisfied with the results.
http://www.coolbulbs.com/HID-VISUAL-...-PROCEDURE.pdf
Old Jul 7, 2013 | 07:13 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Not to hijack Steve but when are we gonna do breakfast at Mt. Dora someday so I can see your car - heck I'll even buy!
To Headlight aiming
Old Jul 7, 2013 | 07:34 PM
Kerrmudgeon
I used to do it on the garage door. Get them level and go out and see if I liked the height on a dark night, if not change it. I had quartz halogens on my 66 (and my 62) and you have to do those different because the lenses have cut-aways to the right side to see the side of the road better, and not to blind oncoming drivers.
Old Jul 7, 2013 | 08:04 PM
RatDog's Avatar
RatDog
Wow! An offer to buy my car <LOL>.
Seriously, breakfast sounds great. Most anytime is good for me. I'm on retirement standard time. Just let me know what's good for you. Love to see your '61 (or the Chevelle, I like them both).
-- Steve
Old Jul 7, 2013 | 08:06 PM
RatDog's Avatar
RatDog
Thanks, everyone, for all the headlight aiming help. This forum is great.
-- Steve
