L76 vs L84
Old Jul 9, 2013 | 04:03 PM
mallie's Avatar
mallie
Default L76 vs L84
Is the L84 much faster (if at all) than the L76?
L84 seems to generate its max torque at higher RPM.
My 65 Coupe L76 is really nice to drive, plenty fast, BUT i feel the acceleration/power curve is somewhat too linear, not much of a really kick, and I got 4.11 rear end. It pulls hard all the way but never gives me neck snapping accelerations I was used to with my 2008 Z06 (ok, I know one can't compare the 2 cars). Wondering if that's just the way the L76 runs (I know it's a bit weak on low end torque). I usually get a bit of an extra kick at around 5500rpm and shifts soon after (i might be able to push it more but i'm always a bit hesitant...).
Old Jul 9, 2013 | 04:08 PM
JohnZ's Avatar
JohnZ
The L76 and L84 are identical engines in all respects except one has a carb and the other has an F.I. unit; otherwise they're mechanically identical.
Old Jul 9, 2013 | 04:10 PM
mallie's Avatar
mallie
So what does FI add? Better mileage? I'm already getting astonishing good mileage, 10-12mpg! ))
Old Jul 9, 2013 | 04:42 PM
MikeM's Avatar
MikeM
I won't argue over which one is faster. I do have an opinion though. The drag racer types I THINK preferred the carb engine. The road racers, the FI engines.
The FI will give better mileage, it's smoother and has better throttle response than the carbureted engine.
You could answer your question easy enough. Just do some track time with your car as is and then bolt on the FI unit and do the same tricks.
Old Jul 9, 2013 | 04:43 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
i've had FI cars for 45+ years, in my humble opinion.... FI provides much better driveability and mileage than a carbed engine; AND, by MY seat-of-the pants it adds to the lowend performance..
Bill
Old Jul 9, 2013 | 08:52 PM
ifitgoesfast's Avatar
ifitgoesfast
I've always understood the FI's were preferable to the carbs particularly for road racing because in the hard turns the carbs would either flood or empty out.
Old Jul 9, 2013 | 09:24 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
A Rochester FI is trick, a Holley ain't!
Old Jul 9, 2013 | 09:29 PM
RestoMike's Avatar
RestoMike
From: Livin' large and havin' fun in wonderful Oklahoma
Whoa up there Tom......my '63 L76 has the Carter carb version!
Old Jul 9, 2013 | 10:04 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
I'm with Tom on this. An FI unit is good eye candy. And the dang things work sooooooo well.
In contrast, when I refer to the carburetor on my bride's road racing track car, I just call it a "big, dumb Holley".
Jim
To L76 vs L84
