Where does this wire go?
Old Jul 12, 2013 | 10:41 PM
19Vert64's Avatar
19Vert64
Default Where does this wire go?
Not really sure what this is(Red) or where this lose wire(Green) connects
Old Jul 12, 2013 | 11:39 PM
wombvette's Avatar
wombvette
Capacitor probably goes on the brake light switch.
Old Jul 12, 2013 | 11:40 PM
19Vert64's Avatar
19Vert64
Brake lights work, could it be for the hazard lights?
Old Jul 13, 2013 | 12:02 AM
1snake's Avatar
1snake
Nope. The leads of the capacitor go to each side of the brake light switch.
Jim
Old Jul 13, 2013 | 12:04 AM
Velox's Avatar
Velox
Exactly The capacitor has nothing to do with brake lights working or not working, it is a noise suppressor used on cars with radio option. There are several of those on your car in various positions
Name:  Long Island Corvette.jpg
Old Jul 13, 2013 | 12:25 AM
19Vert64's Avatar
19Vert64
Thanks! Try to get it hooked back up tomorrow
Old Jul 13, 2013 | 12:32 AM
19Vert64's Avatar
19Vert64
Does it make a difference which one hooks up to which side?
Old Jul 13, 2013 | 12:51 AM
Velox's Avatar
Velox
Nope. Just FYI capacitors that old probably don't do much, and if they do, it's only for AM reception noise, and not FM, so good chance you won't notice any difference
Old Jul 13, 2013 | 12:53 AM
19Vert64's Avatar
19Vert64
Lol the radio doesn't work just hate having the wires hanging and not where they go
Old Jul 13, 2013 | 01:27 AM
62vetteman's Avatar
62vetteman
Here's a post from the other day that has a photo of the capacitor connected to the brake light switch. See entry #11 .
http://forums.corvetteforum.com/c1-a...g-because.html
Old Jul 13, 2013 | 01:58 AM
Roy Nakamura's Avatar
Roy Nakamura
Attachment 47729716
Velox...would you suggest that while my dash is totally dismantled that I take the opportunity to 'replace' all the original capacitors? There are so many...and I've noticed that in the Corvette parts catalog that they are not cheap either....
Old Jul 13, 2013 | 09:31 AM
Velox's Avatar
Velox
Well I wouldn't, but that's just my opinion. If you are looking for correct restoration I would be mainly concerned that they are present in the correct areas as identified in your AIM. As far as replacing ones already there, again, these are just for noise suppression for AM radio only... Inspect them all, install missing ones, replace any that have deteriorated significantly like broken wires, torn covers, distorted cases
Old Jul 13, 2013 | 10:38 AM
Roy Nakamura
Thank you Velox for your recommendation. I'm not too concerned about the restoration...I was just trying to reap any benefits from having 'fresh capacitors' but if the only benefit would be better AM reception... I just kept my old crusty capacitors.
To Where does this wire go?
