66 Headlamp motor problems.
Old Sep 28, 2013 | 08:57 PM
62Jeff's Avatar
62Jeff
Originally Posted by gman1001
Tx man! Curious, how do you see what your working on? From what I can tell the headlight motors are tucked up under the nose of the car, with the hood on there is only a small area between nose and hood. Tuff to see in there!
First I put a small mirror down in the nose of the car so that I could look down at it and see the motors in the reflection.
Then I just visualized where things were and worked by feel.
I posted these instructions for a member yesterday, perhaps they will assist you as well.
1) Remove the wiring (off-white connector) from the motor by pulling straight out. This photo shows the passenger side motor.
2) Remove the small screw on the support bracket, shown in the photo above holding on a ground wire, and remove the bracket from the car. The other end you can see just slips into a rubber grommet - although in this photo it's almost out of that grommet.
3) Remove the clip (circled in red) that locates the motor on the bucket shaft. This clip is normally shaped more like a bobby pin, but in this photo it's an "e" clip. This photo shows the driver's side motor.
4) Pull the headlight motor straight away from the bucket and off the shaft. Remove it from the car by lifting the hood over center and snaking the motor out through the gap between the nose and the hood.
And then if you need info on how to rebuild them once they are out, go here:
http://www.lbfun.com/warehouse/tech_...%20Rebuild.pdf
Old Sep 28, 2013 | 09:00 PM
gman1001's Avatar
gman1001
Just printed these out! Thank you so much! Even just the hint on mirror usage is key!
Old Sep 28, 2013 | 09:02 PM
62Jeff's Avatar
62Jeff
You are very welcome.
Old Sep 29, 2013 | 12:33 PM
TheSaint's Avatar
TheSaint
Downloaded this instructions on my computer so i have them if i decide to change to Detroit Speed headlights
Thanks for posting
Old Sep 29, 2013 | 02:02 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Originally Posted by Iggycat2009
I just put that kit in my '63 without removing the hood; you have to push the hood past where it normally latches and brace it up at its farthest extension. Then you can get the old motors out, put the new ones in without much difficulty at all. That's not the problem with the kit. The problem is that, if you have original wiring at the headlight connector, there is NO 'give' to that harness so pulling out the connector pins at the light switch to wire in the control module is one royal PITA. That took more time on mine than the motors by far.
Once installed, though the lights work magically. Snap up in unison and shut just as quickly. The kit is beautifully designed and thought out and worth the cost/effort if your old motors are kaput.
Old Sep 30, 2013 | 06:19 AM
Revfan's Avatar
Revfan
Wow... this actually worked! Got my right side working... it wasn't before. Now it makes the working good side look like a sloth!
Took about an hour to get it out and apart, cleaned and back together. Then it took another 30 minutes to get it back in.
ughhh.
I was almost, just about, ready to take the hood off to get it back in. Then I thought that the motor "slot" where the headlight bucket arm enters the motor may have gotten turned... so I opened the headlight bucket and it slipped in in about 10 seconds.
I'll do the other one "later"... bigger fish to fry before my German inspection.
Cheers!
Old Sep 30, 2013 | 12:17 PM
gman1001's Avatar
gman1001
Tx all, question - whats the best type of grease to use when rebuilding these headlight motors. I'm thinking Teflon or maybe axle grease.
Thoughts?
Old Jan 3, 2022 | 06:51 PM
AU812's Avatar
AU812
St. Jude Donor '21
Brake cleaner, not brake fluid.
If you choose to pull them and look into this yourself, here's an article telling you how. I went from 2 non-functional motors, to 2 working motors in a matter of hours by simply following the instructions in this link:
This old thread relates to rebuilding headlight motors, and the link to the pdf article from post #4 is dead. Does anyone have a copy that they can repost? Thanks.
Old Jan 5, 2022 | 12:07 AM
buns's Avatar
buns
Not sure if this is the one you're looking for................
File Type: pdf
Old Jan 5, 2022 | 01:16 PM
AU812's Avatar
AU812
St. Jude Donor '21
Thanks--that's a very good article--probably the one I was looking for.
Old Jan 5, 2022 | 01:43 PM
1960's Avatar
1960
I learned right here on the forum , these guys know their stuff . Do it yourself , actually easy once you do it and it fixed mine .. Bob
